Question about HP Photosmart D7460 Printer
On my Photosmart D7460 HP printer, the error code 0005FBB6 keeps coming on the screen saying that I have not powered down properly... not allowing me to print and setting off all sorts of flashing lights... what can i do? Thanks
  • 30 Answers
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
Posted on Mar 27, 2011
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
May 06, 2011 | HP Photosmart D7460 Printer
My hp photosmart D7460 keep saying that 3 of my inks are out - just replace all of them still get that message - Is there anything that you can do?
Do the basic troubleshooting first before you consult an expert. Basic like try re-installing your software, the old software may be corrupted and need to be updated. Second is to check the cartridge if it is properly place and try to check if your cartridge is defective printer may not recognize your cartridge if it is defective...thats the basic one..if you need my help i will surely glad to help you please contact me at my email add jekjekoy@yahoo.com.ph...merry xmas
Dec 22, 2010 | HP Photosmart D7460 Printer
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
How to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Mar 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Where to disable color management in printer driver dialog box
When you go to print.  In the box that say's print with printer/presets there's another that say's copies and pages, scroll down to Color Management. Then you will see a Off (No Color Adjustment). Try that and also in the same dialog box is Print Settings that's where you put your paper type selection. Hope this helps
Dec 18, 2008 | HP Photosmart D7460 Printer
HP D7460 printing blank pages, no error message
Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
Nov 22, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7460 Printer Logo
321 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
