I suspect that the iron is clogged with mineral deposits. This happens when ordinary tap water is used - more so if your tap water is "hard". First and foremost, buy a gallon of
DISTILLED water.
Cleaning it is very much like cleaning an auto drip coffee maker. Empty the iron into the sink. The first method is to pour white vinegar into the reservoir and set the iron to the hottest setting. Tip the iron flat to allow steam to escape. Press any buttons that allow blasts of steam, too. The vinegar will dissolve minerals on the inside of the iron and clogging the holes on the bottom of it. If all holes are cleared after the first time, flush
DISTILLED water thru the iron. If not cleared, you can try this second method: Fill it with vinegar again and leave it sitting flat in the sink - unplugged - over night. In the morning, refill with vinegar as needed and try the first method once more. It should be clear at this point. Flush with
DISTILLED water.
You can prevent this from happening again by using
DISTILLED water
only in the iron. There are NO minerals in
DISTILLED water, which are left in the iron when water is boiled off inside it.
