Question about RTO Basement Watchdog Sump Pump
I have a Basement Watchdog sump pump system. I just replaced the battery three weeks ago, all acid levels even and full, but the alarm will not stop sounding, with the battery indicator light on. Two things happened when I bought it, though. 1) It was a newer style battery that I replace for an old one. The old one had a hole in the battery for the sensor, and the new one using the yellow cap for the sensor. 2) Since I had no yellow cap, I brought the battery back to Home Depot to exchange, but was given a yellow cap. However, the foil covering the holes was removed for a few hours as the battery was transported back and forth to The Home Depot. Any ideas? This battery is driving me crazy. Thanks for your help
  • Denice DuPlanti
    Denice DuPlanti Jun 05, 2018
    I am having the same issue, any ideas?
  • RTO Master
  • 2,538 Answers
2 Suggested Answers
glc1620
  • 8 Answers
SOURCE: watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Posted on Sep 10, 2012
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
BACK UP BATTERY FOR MY SUMP PUMP KEEPS BEEPING. I HIT THE RE-SET BUTTON TURNS OFF BUT COMES BACK ON WHEN THE PUMP KICKS ON. THE PUMP DOES SOUND DIFFERENT NOW THAN A FEW DAYS AGO. NOT SURE IF THE BATTERY...
Replace the battery first. It is cheaper than a whole pump. The battery is constantly being charged and will go bad after time even though it does not get used.
Dec 16, 2013 | Zoeller 507-0005 Basement Sentry Battery...
Alarm goes of a night for no reason
The water in the battery might me low. This usually happens in winter when the heat goes on and the air gets dryer. The battery water evaporates faster, but is still very slow out that tiny vent hole in each cell cap. The battery reaches the threshold, and the alram starts to trigger. If this is the case, simply add distilled water to all the cells to the bottom of the fill tube. Don't splash, the sulfuric acid is nasty. Hav baking soda handy to pour on sills, but don't get it it the battery.
Nov 04, 2012 | RTO Basement Watchdog Sump Pump
Watchdog sump pump want stop beeping
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
I have an lg dehumidifier model # LHD65EBLY8. The bucket is full light keeps coming on even though it is empty. Because of this, it will not stay on and my basement keeps flooding. Do you have any...
booklover, if the the bucket is not properly installed, the unit will not turn ON. If you remove the bucket and look at the left top corner it, you will see a float device arm. It that's stuck in the UP position, jiggle the handle, so it will return to the DOWN position. In addition, that handle must make contact with the bucket removal safety switch, if not the bucket is improperly installed and the unit will not start.
Since you are using this unit in a basement, I highly recommend that you raise the unit up off the floor onto a sturdy table, counter top, etc. that can handle the weight if the unit, plus a full bucket of water. As the air temperature at floor level is colder than at chest level. The coils on your model will start to freeze at 60 degrees F and affect it efficiency, Because it is not a Low Temperature model designed for basement applications.
In addition to the dehumidifier, you would be wise to install a sump pump, if your basement floods as bad as you made it sound. Combining a sump pump with a dehumidifier will guarantee a dry basement, all the time.
Hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | LG Dehumidifiers
Battery has liquid on top
The battery is charging with trickle charger. The liquid could be just water from condensation from the recharging process. If the charging is too vigorous, then it can also be sulfuric acid, so rubber gloves are in order. Clean up liquid with gloves on and paper towels. Once dry carefully remove caps and check water level. refill battery with distilled water to top of cell. Check water level at least twice a year. Wear safety glasses too.
Oct 03, 2010 | RTO Basement Watchdog Sump Pump
My backup battery for my sump pump is telling me to recharge the battery. These things are all new to me never had to have one. My model is ace in a hole A5000. Have no manual from the previous owner....
yes but it has to be disconnected before you charge it. also check the battery for water level in all cells. basement watchdog is a better unit. yours on a good battery might run for 4 hours when the powers out. it should have a large deep cycle battery for it to work well
Nov 22, 2017 | Simer 3/4 Hp Stainless Steel Sump Pump
The alarm continues to sound. The red light for battery is on. I did add water and it went off for a very short time m, but then continued. I added more water, definitely full, and it continues to...
(Batteries may be substituted by using a deep cycle marine battery with the same specifications as described above, but the battery fluid sensor option will not function. Simply connect the battery fluid sensor to the positive terminal of the battery to disarm battery fluid sensor alarm).
Aug 05, 2010 | RTO Basement Watchdog Sump Pump
Pump continues to make noise as if its cavitating when there is no water to pump.
If there is no water to pump then it is cavitating. It should turn off when the sump is emptied down and the float drops onto the switch arm
Oct 21, 2009 | RTO Basement Watchdog Sump Pump
RTO Basement Watchdog  Sump Pump Logo
1,072 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
