Question about Garmin nuvi 1300 Car GPS Receiver
I have a Garmin nuvi 1300 vthat will not charge, either form 110v or car, and will not turn on.
  • Charlie Kettell Mar 26, 2011
    Is battery customer replaceable? Does not charge on house current adapter cable either. No lights ,no nothing!
  • Charlie Kettell Mar 29, 2011
    Nothing happens with attempts to reset. Have not yet called customer service to ask about battery replacement
  • 794 Answers
Hi cwkettell,
With the issue that you are having with your system that it won't turn on you may try doing two types of resets. The first one is the basic reset. This can be done by pressing the Power button for 20-30 seconds. The other is a Master Reset that can be done by doing the steps I have for you below:
Note: A master reset will erase all waypoints or Favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes.
The device will automatically reset. Follow the on screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
You can check out with your manufacturer's customer service on how you can replace the battery for your unit. You may call them from Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time. Toll free number is: 1-800-800-1020.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 26, 2011
  • Jemalyn Labaguis Mar 29, 2011
    Hi cwkettell,
    Please contact your manufacturer's customer service so they can immediately assist you about the replacement of your system's battery.
    Hi cwkettell,
    There's a battery inside your GPS. It is "hardwired" into your GPS. For it to be replaced you need to send it back to Garmin or you may contact an authorized GPS repair station nearest to your area. Your GPS requires a special tool and a skilled person to replace the battery. It needs to be soldered back to the unit, any attempt in removing the battery might result a damaged GPS if the proper tool is not being used.
    Hope it helps.
    Top Expert:
  • Garmin Master
  • 75,774 Answers
Hello
Either its battery has damaged or it doesn't get voltage to charge on. Check the fuse in its vehicle power cable. If it found open, replace the same with similar one. If your unit will not charge in your vehicle you might need to replace the fuse located at the tip of the vehicle adapter. Unscrew the back, round end piece, and remove it. Remove the fuse [glass and silver cylinder] and replace it with 1 Ampere Fast Blow Fuse. Ensure that the silver tip is placed in the back end piece. Screw on the back end piece.
If the battery does not stay for a very long time, between charges, turn down the back light. Touch TOOLS >> SETTINGS >> DISPLAY >> BRIGHTNESS
If the fuse inside the fuse cartridge is found Ok and still battery does not charges, battery is bad, and replace it. OK.
  • The Knight
    The Knight Mar 27, 2011
    No. The battery is of maintanance free, and is not repairable. It should be replaced with same type and voltage ratings.
Can I use my Garmin nuvi 1300 while it is charging via USB cable? This will be it's first use.
I HAD A PROBLEM CHARGING MY 1300 GARMIN. I PUT A SCREW DRIVER BLADE ON THE TWO SIDE CONTACTS OF THE CHARGING CABLE AND TURNED THE BLADE TO SPREAD THE CONTACTS OUT JUST A LITTLE. IT NOW WORKS FINE
Dec 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
GPS was working fine. Stopped and turned off car....
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
My gps is not turning on. I tried to charge but there is no signal. Can you please help me?
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
The Garmin Nuvi 1300 was working gret. It was a Chrismas gift. It just stopped working it will not come on at all the screen is blank black. No signal will not turn on at all. Did not drop it or and other...
I hope that helps.
May 11, 2010 | Garmin nuvi 1300 Car GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
I hope that helps.
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
The Garmin Nuvi 1300 was working gret. it was a Chrismas gift. It just stopped working, it will not come on at all the screen is blank, black. No signal will not turn on at all. Did not drop it or and...
I hope that helps.
Mar 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Cant get gps to switch on after charging in car facing the sun? dont have manual to help me. I am not the best using the computer.
I hope that helps.
Jan 30, 2010 | Garmin nuvi 1300 Car GPS Receiver
I just got a Garmin nuvi 1300 for Christmas and it has worked just fine for almost 2 weeks. Then yesterday, out of the blue, it shut off for a few hours and would not turn back on. It did the same thing...
I hope that helps.
Jan 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1300 won't turn on. It should be fully charged as I drove a couple hours with it plugged into my cigarette lighter. Nothing happens when I push the power button. I've had it for not even a...
I hope that helps.
Dec 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
260 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
