Question about McCulloch 14" Electric Chain Saw Mcc1514
Removing a link to shorten...stretched - McCulloch 14" Electric Chain Saw Mcc1514
  • McCulloch Master
  • 2,239 Answers
It is never a good idea to shorten a chain, if it has stretced that bad you need to replace it, or it will snap, the chain does not have a joiner, you would need to break the chain, and re rivet a new pre set tie strap.
Posted on Mar 26, 2011
What stitch should I use to sew stretch cotton fabric
Hard to tell because your machine is unidentified.
Jul 14, 2017 | Sewing Machines
I need to take out some links in the chain on a liftmaster garage door opener. How do I do this? It is about 20 months old.
Two ways!
On the cable section of the chain use a cable shorten-er.
On the chain remove excess chain and install a master link/
26357047-x15jo43ndspuozxlydbahatb-3-2.jpg Master link/ You would need to go to a bicycle shop to have the chain shortened.
26357047-x15jo43ndspuozxlydbahatb-3-5.jpg Check to make sure you can not extend the rail before cutting chain. The cable shorten-ers will likely be available at an auto parts store. They are used to adjust the parking brake!
HJope this helps?
Nov 15, 2016 | Building Materials
Pir crust stretches
To make a flaky crust you need to use a lot of shortening or butter.
Apr 17, 2014 | Cooking
Free play on chain fzr 1000 1991
Must be no more than 1 and 1/2 inches overall. ( from fully up to fully down) measured in the middle of the lower chain run.
May 22, 2012 | 1991 Yamaha FZR 1000
How do I shorten my Ice watch strap?
mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
Jul 17, 2010 | Watches
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
1999 Toyota Sienna Drivers Side Sliding door hard to open from the outside only - OK using inside latch. (think maybe cable attached to inside latch is "stretched". What's involved in removing interior...
well they dont use cables they use a iron rod so just snap off the pannel the snaps are in the out side of the door then just remove the arm rest and the panel comes right off remove the dirt cover then just tighen it and it will work again
Nov 06, 2009 | 2001 Toyota Sienna
How do I shorten the watchband to fit my wrist?
If you turn the band inside out...and stretch it...you will see either 2 or 4 small tabs per section. Use a jewelers screwdriver to lift up each tab per section and slide that section out. Now it will be easy to take other sections out as you won't have to maintain pressure on the band. Reassembly is reverse order.
Apr 24, 2009 | Watches
Changin chain on 2002 honda shadow ace
Unless you are changing sprocket sizes you can not shorten the chain because removing even one link would not allow the ends to connect. Are you adjusting the chain as needed? Why do you want to shorten it?
Even if the factory chain has no master link (some are continuous these days) you can still grind off two pins carefully and push out a link to remove the chain, or simply cut it. That is what you must do when replacing the chain.
Apr 05, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
McCulloch 14" Electric Chain Saw Mcc1514 Logo
115 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
