Question about Kenmore Refrigerators
Kenmore elite model # 795.77546600 intermittent interior light
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
  • 1122 Answers
SOURCE: kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Posted on Oct 01, 2008
codfish124
  • 36 Answers
SOURCE: kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Posted on Dec 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: I am getting an ER
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&#%#
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 795 77244601
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Kenmore elite washing machine interior light does not shutoff model 796.41022900. Light still on after several hours. Tried unplugging and plugging back.
This could be expensive to repair. From looking at the parts list, there are only two things it could be. One is the door switch and the other is the main control board. If it was the door switch the unit would not operate. Therefore it is the main board.
Apr 19, 2017 | Kenmore Washing Machines
Kenmore Elite microwave model 85513 doesn't heat like it use to only 1/3 power what has to be replaced
An intermittent or failing magnetron could cause the problem. Although extremely rare, an intermittent high voltage rectifier can also cause this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 16, 2016 | Kenmore Microwave Ovens
Kenmore elite washer - interior light wont turn off
sounds like the door switch. put a piece of tape or something on the switch and close the door and see if taking the slack out of the switch makes it start. Or, hold the switch in while pushing start. DO NOT put any body part inside dryer when doing this.. If this works the switch needs some adjusting.. how to do that I do not know. May be a bad switch, I just replaced mine on a kenmore other week. Maybe repairclinic.com could help ya.. have model number ready when you go to the site and look at the possible reasons. Hope this helps.
Oct 12, 2014 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Kenmore elite he4 dryer model # 110.95874400 not turning on
Suggest you check the door switch, that is one of the things that could cause your symptoms and is the most common failure items.
Jan 23, 2012 | Kenmore Dryers
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore elite 77573600
Dec 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Sears Kenmore Elite Frig Interion Light Wont Extinquish
Kevinh987,
I would suggest you contact Sears and ask them to repair it free of charge, I am not aware of this model as I am from the Great North. Depending who the OEM is, if Sears did not want to fix it, I would go after them.
Sgt 48
Aug 26, 2008 | Refrigerators
Refrigerators Logo
207 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
