Question about Amana Kitchen Ranges
I have an Amana Model # AER5735QAQ the bottom Bake element Burned out melted, I replaced the Bake element and the long oven sensor and it still does not heat, Can you help?
  • Amana Master
  • 2,699 Answers
Sometimes when the element pops it also can take out the relay in the clock assy.you can try unplugging the machine,pull it out and remove the back panel,check for melted wires or loose wires going to the element,also you can plug it back in,at the block where the cord connects make sure you have 240 volts coming to the machine,check this with a meter,when it popped it could of damaged the braker,if everything checks good i'd have to say you have a bad relay on the clock assy.part number 74009220 and it's around 180 dollars.call your parts store and give them the model number to make sure this is the correct part number.good luck and let me know how you make out.
Posted on Mar 26, 2011
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
Oven not heating up but only broiler works heating element looks ok
Hi There
I have found some stuff for you to read and hope this will help you get you in the right direction.let me know how this goes.
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. Thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kitchen Ranges
The broiler works but the bake side wont heat up but does warm
Hi There
I have found some stuff for you to read and hope this will help. Let me know how it goes.
Dec 30, 2009 | Ovens
Oven wont heat up
Sounds like the bake element burned out. Look at the bottom heating element in the oven and see if there are any melted spots. Do NOT touch it.
Dec 28, 2009 | Kenmore Kitchen Ranges
We have an Amana Range/Oven ARG7102W, Manufacture #P1143347N W. The oven does not heat up to the temp set. We purchased an oven thermometer to check the temp. In order to reach 350 degrees, we have to...
Hi...
A main wire burned off will cause both elements to not heat at the same time. It could be at the back going to one element then jump off and go to the second element. Or some times the manufacturer runs the wiring to the front on the controls, and a 3rd area that they could have a common tie point is right where the power comes into the oven. When this usually happens you'll have ok burners on top and no power completed to the bottom.
OR
It could be a switch that's bad and not allowing power to carry on to your oven controls at the thermostat.
Let me know
Thanks
Smith
Aug 20, 2009 | Kitchen Ranges
Wont heat past 200 degres
May 27, 2009 | Ovens
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Thermador oven
If oven does not heat check heating element and oven control. Follow also suggestion below:
" It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
From repairclinic
Aug 17, 2008 | Thermador PGR366 Gas Kitchen Range
I self cleaned my Amana oven model acf7225aw. During the cleaning there was a huge pop and then all power was shut off to the oven (no power to clock or anything). We flipped the breaker- another pop. ...
Yes you probably have a burned out bake or broil element in the oven. They usually short out to the frame when they go and can have some interesting results. A direct short probably burned out half of the circuit breaker and you are now only getting 120 volts to the stove and its feeding back through the shorted element and giving some heat. Unplug the stove reset the circuit breaker and test the outlet for proper power. Outer holes will read 220 volts to each other and 110 volts to the middle hole. Replace the circuit breaker if needed. Usually when an element burns out it is visible. If not remove both bake and broil elements and take them to the parts store and ask them to see which one is bad. It is very unlikely they both burned out.
Jun 28, 2008 | Amana Kitchen Ranges
Kitchen Ranges Logo
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
