Question about Olympus Cameras
There seems to be some kind of short and the camera runs thru batteries like crazy. I also need the cable that connects the camera to the commuter to transferphotos.
    President:
  • 778 Answers
Not sure which Olympus you have, but I own an Olympus SP-550UZ and it uses 4 AA batteries and uses a USB to USB mini as Voodoomox posted a picture of to sync to PC with. That cable is not proprietary and very inexpensive, so you can pick one up locally or find one online without a problem.
I found that even Duracell Ultra AA batteries don't hold up very long in any of my digital cameras, so I switched to NiMh (Nickle Metal Hydride) 2600 MAh rechargeable batteries and a charging station and they seem to last 3 to 4 times longer than the best Alkaline batteries I've used. I haven't reached 100 recharges on any of my batteries yet, but that is the number of recharge cycles that their advertised to last for.
Posted on Aug 04, 2008
  • Frank  Fernandez
    Frank Fernandez Aug 10, 2008
    I inferred that the batteries in question were Alkaline batteries from "runs through batteries like crazy" and have yet to see any Li/on batteries to replace Alkaline, that's why I recommended NiMh and not Li/ion (as I agree Lithium ion are the superior rechargeable). My Sony uses Lithium ion but my Olympus uses AA.
  • 659 Answers
Are you using rechargable batteries? if so everytime they charge they loose a bit of power sucking up the power quicker then before.
if its a rechargable battery by the company themselfs make sure there is a warrenty on it.
Also id recomend the Energizer e2 Lithium batteries.
any you can go here http://www.olympusamerica.com/cpg_section/cpg_accessory.asp
to find the accessories that fit your model i take it that its a olympus camera?
if not let me know and I will find you more info
then you can either order from their site I think or you can search around ebay for a suitable deal on them or be able to go to your digital camera dealer to find a replacement since you will have the product number ect.
    Genius:
  • 1,689 Answers
Try replace your battery with a Lithium Ion, better if you bring your camera to best buy, walmart or circuit city show them your camera then look for the kind of battery i mentioned.
for the USB cable to transfer files, once you are in the store, look for a USB cable that loks like the on int the picture, this should not cost you more than $5
  • 6,487 Answers
You need to replace the battery you can go to this link and check order the battery and USB cable that you need http://www.amazon.com/Olympus-CBUSB4-Digital-Camera-Cameras/dp/B00007EDVJ
Hope that helps...........
SOURCE:
My Bernina 801 sport will not sew. When I step on the foot pedal, nothing happens. Sometimes it will sew for a few seconds and then stop. I cleaned it out but still will not sew
There can be a few problems that match your inquiry. Pleas check the machine in the following logical order:
  1. The power cable can be defective....With the machine plugged in and un-threaded, step on the foot control to check for a motor run condition and at the same time wiggle the cables at the motor plug connection. If the machine runs/stops/runs and stops, it is likely that the cables and or plug are damaged. Replace the cable. If the cable is found to be good, go to step 2.
  2. Check the motor run condition by changing foot controls. If the machine runs without a run/stop problem, the original foot control will have to be rebuilt. If the foot control is found to be good, go to step 3. Step 3 is for a qualified technician level of competency only.
  3. Remove the power cable, back cover, motor belt, motor housing. Remove the closing plate on the back of the motor housing to inspect the motor brushes. If the carbon brushes have worn out, you will probably find some damage to the commutator bars due to the brush springs having arc-worn the commutator. Generally, this type of damage can be repaired with excellent results. Most of the time however, motor brushes are installed by a sewing machine repair person, but no effort is made to repair the damage by resurfacing the commutator to a precision cylindrical diameter. This being the case, new motor brushes will have a very short life and further damage to the motor is likely.. Amateur attempts are sometimes made by applying some sort of tool or sandpaper to the commutator while the motor is running in an attempt to resurface, but concentricity and cylindricity cannot be achieved in such a manner....If the motor brushes are good go to step 4.
  4. Examine the commutator bars on the motor armature carefully for any burned spots on the borders of the copper commutator bar insulators. If such burn spots are evident, the armature will have two or more dead spots. At this point, the motor should be replaced.
http://www.sewtechnical.com/
Jul 21, 2015 | Bernina Sewing Machines
My 2003 kia sedona was steaming got thermostat it's fine but now all warning lights stay on. My headlights not workand the seatbelt ding sound goes off and on when I drive apply brakes the ding stop
If you have a bad ground connection between battery and frame / body will have all sorts of strange problems. Electricity travels backwards thru all kinds of strange ways. You tube has good tests for checking with a volt meter VOM
You might have got antifreeze on ground cables connection to body. Corrosion. Good luck. My car drove me crazy till I fixed ground. Unbolted cable on body, cleaned connections no more problems
May 27, 2015 | 2003 Kia Sedona
Dash lights go off then come back why
You might have a bad ground connection. If the battery black ground cable is not connecting to the car frame you will have crazy problems. Look up a wireing diagram for your car, there are several ground cables. Rust and corrosion will get them. With bad ground, Power goes backwards thru all kinds of places.
There's some good U-tube videos "Bad Auto Grounding"
May 15, 2015 | Cars & Trucks
Nikon coolpix s5200
Please try removing the battery and after a few moments replace the battery. This should "reset the camera. It has the same effect as a cold boot on a computer.
Never try o switch on a camera, when an USB cable is connected. Only certain camera's, and only when special software is installed on the commuter, can work with the USB cable.
Most cameras, play "dumb" and only accept 5 volt, to charge the battery, or will transport pictures to the computer when connected and the correct software is installed.
I hope the camera will work again.
Success
Jul 25, 2014 | Nikon Coolpix S5200 16 Megapixel Digital...
Alternator not charging battery
voltage regulator, it may be internal in the alternator, if so then you can get a bad one, take alternator off and autozone or advance auto will test it for free. if it is external then it shld be fairly easy to replace note:if its external it usually has a cable running from the battery, and another cable running to either the fusebax or alternator itself
Aug 27, 2012 | Cars & Trucks
The dash lights and all rear running lights go out when the drivers door is opened.
Replace battery if more than 4 years old. Colud also be a shorted or grounded wire comin thru door.
Aug 05, 2012 | 2002 Kia Spectra
I get down the road and my zuma just stops running all at once! I have bought a new spark plug and checked for a spark and there is one so i dont think it is the coil, can you help me?
some kind of short id guess. Or lose or corded connection. Good luck..but I wouldn't run any more until you know for sure what's happening. NOT TO SCARE YOU BUT IF ITS A HOT SHORT YOUR BIKE COULD CATCH FIRE..OR GIVE YOU A SHOCK THRU THE HANDLE BARS AND SWITCHES..DEPENDING WHAT KIND OF SHORT YOUR DEALING WITH....SO BEWARE..AROUND A SHORT THE WIRE WILL LOOK LIKE BABY POWDER KINDA.YOULL KNOW WHEN YOU SEE IT USUAULY NEAR A METAL OBJECT..LIKE THE FRAME OF THE BIKE..THAN TRAVELS TO THE CLOSEST GROUND..THE RIDER.NOTHING TO PLAY WITH VERY SERIOUS..WHEN WORKING ON ANY MOTOR ALWAYS DISCONNECT THE POSTIVE BATTERY CABLE AND WRAP IT IN PLASTIC SO IT CANT MAKE A CONNENCTION UNTIL YOUR READY,,OH YEA ONE WAY YOU CAN TELL IF YOU HAVE A SHORT IS WHEN CONNECTING THE POSTIVE,IT WILL SPARK AS IT TOUCHES THE BATTERY THATS A SHORT..MAKE SURE NO LIGHTS OR ANY THING IS TURNING ON WHEN CONNECTNING..THE BIGGER THE SPARK THE WORSE THE SHORT..CAN EVEN WELD ITS SELF TOGETHER..
Sep 23, 2011 | 2005 Yamaha Zuma
I need to know how to wire the power cables and other wires to the amp and then to the subwoofer plz can you help me nath
hey dennis if you have a standard car amplifier all you need to do is run a wire from the battery post straight from the battery to amp batt+ post, then negative side can also be run straight from battery negative, than the remote post on your amp. you can either utilize the power antenae circuit coming out of the stereo unit or an ignition power from your ignition power fuse box so you don't draw battery power when key is off, please reply back if your stereo unit has rca output and does your amp. have rca connection(rca connections are red and white audio cable style connection).
Sep 28, 2009 | Car Audio & Video
CADILLAC CTS 2003
Are your power seats working? Mine shorted out and several days later my battery was dead because the short was drawing power from the battery when the car was not running. If your battery and charging system check out o.k, I would say you have some kind of parasitic drain on your battery.
Dec 30, 2008 | 2003 Cadillac CTS
Cameras Logo
44 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
