Question about Philips FR931 Receiver
I HAVE PHILIPS AMP FR931 AND I HAVE A HITACHI HT4 TURN TABLE THAT PRODUCES A LOW VOLUME SOUND WHEN THEY ARE CONNECTED.
    Brigadier General:
  • 8,546 Answers
I can't find anything about the HT4 but it should be connected to PHONO (nowhere else) if it has a moving magnet cartridge and you should set the PHONO/LINE selector to PHONO.
http://www.p4c.philips.com/files/f/fr931_p00/fr931_p00_dfu_eng.pdf
Posted on Mar 26, 2011
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
Low sound, at maximum volume
possible reasons
is there a volume limiter switched on in the menu?
Is whatever is feeding the amp at the correct level, are you feeding from line out or does it depend on tv's volume settings?
Is it distorted, if not the amp is probably ok
Mar 07, 2011 | Philips Audio Players & Recorders
My turn table works properly but its volume is too low thu the amp is perfect. the needls are new too
Look it can either be one of 3 things. (1) Cartridge knackered. 2 Internal pre-amp in turntable. 3 Cartridge Pre-amp in Main amp connected to it.
To solve (1) disconnect all wires to cartridge. With the turntable connected to main amp - touch each channel wire (that connects to cart) with your finger. If you hear a decent buzz the cart has gone. A weak buzz and the other two could be still to blame.
Remember all functions on your main amp can work fine, but that pre-amp for the cartridge (often a single IC) can be dead or weak.
Jun 06, 2010 | Technics SL-1210 Turntable
Ipod docks to philips sound bar, but produces no sound...
Check the iPod dock connector for dust or pocket-lint. Use compressed air to blow it out if there's debris in there.
Then check the sound bar's connector to make sure the universal dock connector is clean and doesn't have any damage to the connector.
Jan 14, 2010 | Philips SoundBar DVD Home Theater with...
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
Hitachi 27ax1b volume problems
If the audio is not distorted, but low. I would suggest a coupling capacitor from the audio processor to the audio output amp ic.
Feb 24, 2008 | Televison & Video
No sound
MCM720 is one of the biggest CRAPS that Philips ever produced. if it is low volume, it produces 1250 Hz background noises that are real pain in the a... . If you go up with volume, amplifier goes into temporary shutdown. Just return and get money back and buy something better. Borut
Aug 08, 2007 | Philips MCM720 Shelf System
136 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
