How to repait an internal hard drive - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
If you are having problems with your hard drive the first cause could be a bad faulty lead
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Posted on Mar 26, 2011
  • Brian Sullivan
    Brian Sullivan Mar 26, 2011
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
1992 Ford Mustang transmission slips out of overdrive
if fluid level is full check condition of fluid, if it looks or smells burnt, the problem is internal and will require removal for repait
Sep 02, 2013 | 1994 BMW 3 Series
I have a Lenovo H430 Desktop & i Got a Seagate 3Tb Internal Hard Drive & i can't get the computer to detect the hard drive & everything i have tried & even Seagate tried nothing wo
hi..there...
why your lenovo H430 Desktop cannot detect your internal Hard Drive Seagate 3 TB ..because your Lenovo only support maximum 2TB Internal Hard Drive..
so the best thing to solve your problem is replace your hard drive and use only maximum 2 TB for your internal hard drive..
that's will make your lenovo works again
Aug 24, 2012 | Computers & Internet
What are some example of hard drives?
A hard drive is the main component that the computer relies on.
On the hard drive, the operating system is stored, also includes your pictures, videos, music, documents, etc.
No operating system on...
there are other portable hard drives or mass storage devices
2.5 3.5 internal and external hard drives
usb external hard drives
usb pendrives
usb flash drives
ide internal hard drives
sata internal hard drives
hope this helps
Jul 13, 2012 | Samsung Computers & Internet
How do I replace the internal hard drive
well before that why not run a disk optimizer and see if that helps
click here for a neat utility
Jun 17, 2012 | Fantom Drives MicroNet Platinum 160 GB...
My external hard drive is 300g,i formatted my internal hard drive and found that my external drive was also formatted and was only 3g.could someone help me please that's a lot of space lost
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
Internal hard drive
They do make cases that you can buy to turn an internal HD into an external. Best Buy I think sells them.
Dec 19, 2009 | Seagate 160GB 3.5" External USB Drive 160...
Dismantling acer aspire 1300 laptop to repait power supply inlet removed all screws from underneath but appears to be still connected somewhere at the back inside centrally ?
Have you removed the panels from the bottom of the computer? There could be a screw or two accessible only from within the space occupied by the memory or hard drive or modem. I have also seen machines that have a screw under the keyboard.
If it appears to be fastened at the back, remove the studs that hold the SVGA port to the case.
Sep 17, 2009 | Acer Aspire 1300XC Notebook
Adding extra internal hard drive.
make sure you pc is turned off before you start. To add additional internal hard drive you will need to get SATA hard drive. when you open up your pc there will be a slot to put it in. on the new hard drive there will a display with shows you how to make that hard drive a slave. move the little thing to the right place and plug it in. when you restart it should read it .
Dec 16, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
