Question about Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170
Resetting the timer for Auto - Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Hamilton
I do not know how to 'reset timer for auto'
The reset button is small round button with R
Manual says: "ON/AUTO/OFF" override. Press "ON/AUTO/OFF" or the
button with the "HAND" symbol to force the timer into permanent
"ON" "AUTO" program or permanent "OFF" mode.'
When within the programmed window (preset time period),
cycle through "ON/AUTO/OFF" button to "ON" mode
(indicated by lighted red LED above display), and then
"AUTO"
I have not tested this timer, but the manual sounds vague and confusing, leading me to believe you have to tinker around with the buttons and settings to make sense.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 27, 2011
Canon powershot stuck in auto mode
In the menu try resetting to factory settings.
Feb 09, 2014 | Canon Powershot A4000 16mp 3" Lcd 8x...
I have the timer programmed but what mode should it be in Off, Auto or Random? I had it in Auto but the timer did not start at 10 am as programmed! Help!
HB88RC is discontinued timer, replaced by 2-outlet HB800RCL or 1-outlet HB800RCH.
Timer functions should work in AUTO.
Try resetting timer by removing AA battery, reinstall fresh battery, and then reprogram timer.
When programming is finished, press clock button and timer should be in AUTO mode and current time displayed.
If you want to change mode, then press mode button. When exiting mode, press clock button and timer should be back in AUTO mode.
If functionality does not restore, then timer has gone bad.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://waterheatertimer.org/pdf/hb88rc.pdf
Jul 05, 2011 | Intermatic HB88RC Outdoor Timer
The grill works but the fan over does not. What do I need to do to fix it?
Hi Your clock timer is probably on automatic try resetting the clock If it is on auto you will have a auto light up somewhere in the display
May 27, 2011 | Whirlpool AKZ159IX Oven
Even though the times are all set correctly, and it is on AUTO mode, the timer automatically turns itself to OFF after one cycle. So say i have the timer set from 1-1:15 and from 2-2:15, it always goes...
look at your manual, and then add a comment with brand and model number of timer.
or
Describe timer in detail and I will find a manual that matches your product and read it alongside you.
I test timers, some arrive defective, some go bad after a few months, most have 1 year limited warranty. Some timers suggest resetting timer when problems occur. Some timers have reset button, other timers have to be unplugged, other timers require you to hold on-off button while pushing reset button.
Add a comment for more free help.
Mar 02, 2011 | Garden
Ecoplus Digital 120v Timer Dual Outlet 24hr 7day Timer: my timer is not cutting on when i have it set to....
Make sure your timmer is set to "AUTO" mode and that your programed times/weekdays are good, resetting the timmer should solve your issue i've had it before, these timmers do this to me once and a while.
Make sure you dont have an "O" on the left of your time as this randomises off/on times by 2 to 32 mins. Press "HOUR" and "MINUTES" at the same time to toggle this option.
the timers manual can be found here:
Eco Plus Digital Timer
May 18, 2010 | Day-Timer Ecoplus Digital 120v Timer Dual...
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Dec 08, 2008 | Coleman Cable Outdoor Easy Set Timer #4604
Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170 Logo
109 people viewed this question
Top Vista Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Vista Hardware and Accessory Expert? Answer questions, earn points and help others
