Question about Marin Muirwoods 29er Hybrid Bike 2009 Closeout
Cannot remove rear wheel on my marin muirwoods 2009, do not have the five sided alunkey required. Any thoughts?
    Guru:
  • 347 Answers
You need to either go to a bike shop or hardware store and buy the allen key.
Or take into a bike shop and they will remove for you.
Posted on Mar 26, 2011
How do I remove rear brake disc 2009 berlingo
jack up rear wheel making sure you place a choc in front of front wheel, remove the wheel, remove the brake caliper there will be 2 bolts at back of brake disc you will then be able to undo then centre nut to remove the disc , if replacing disc it is best practise to replace both sides and renew the pads at the same time
Sep 24, 2014 | Cars & Trucks
Rear wheel removal on a 2009 V Max
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starvmax.com/kunena/13-technical-vmax-discussion/133190-rear-wheel-removal/mode-replies
2009 VMX17 Rear Wheel Axle Bolt Trick
Yamaha Vmax VMX17C 2009 Service Manual
OEM parts for Yamaha
YAMAHA VMX17 Owner Manual
Jan 16, 2013 | 2009 Yamaha VMAX
2009 VRSCF
Here's a quick take from the official H-D release. The wide, angular air-box cover and chopped tail section look as solid and smooth as billet and give the new V-Rod Muscle lines that are clean and powerful. The size of the massive 240 mm rear tire is accentuated by the new broad, clipped and clean rear fender. The combination stop/tail/turn LED light is tucked under the edge of the rear fender, and the side-mount license plate leaves the fender surface smooth and uncluttered. Front-end styling balances the rear, with a trimmed fender that's blacked out behind satin-finished inverted forks and LED turn signals integrated into the mirror stems. The radiator shrouds are restyled and color-matched to the rest of the bodywork, while the new airbox side covers incorporate air scoop inlets covered with woven wire mesh. The silver five-spoke cast aluminum front and rear wheels are a new design for the V-Rod line.
Jul 26, 2012 | 2009 Harley Davidson VRSCF VRod Muscle
2008 Mercury Mariner rear axle is leaking. Is there a possibility I can just tighten it down or will it require me to replace it?
You have to loosen the rear suspension on that side
Remove the axle nut & pull the knuckle clear of the axle
Then remove the axle on the side that leaks
Change the seal & replace axle,etc.
Jul 08, 2012 | 2008 Mercury Mariner
How do I activate 4 wheel drive in the 2008 mercury mariner?
Your vehicle is equipped with an intelligent 4WD System that
continuously monitors vehicle conditions and automatically adjusts the
power distribution between the front and rear wheels. It combines
transparent all-surface operation with highly capable four-wheel drive.
The 4WD system is always active and requires no driver input. It is
capable of handling all road conditions, including street and highway
driving as well as off-road and winter driving.
Jan 12, 2012 | 2008 Mercury Mariner
How can I remove rear wheel from Ducati monster 696?
Raise the rear of the bike on a single sided paddock stand, undo the big nut on the wheel and slide the wheel off.
Dec 19, 2011 | 2009 Ducati Monster 696
How do I remove rear left tyre from 2007 impala, it is sticking to the hub, and wondered ifthere was a trick to it
suggest kick tire on one side or the other,changed millions of those,apply wd40 on hub after removal @ maybe not so hard next time, but 1st are you sure all lug nuts off?
Aug 15, 2010 | 2009 Chevrolet Impala
Front brakes clicking on 2006 Ford 500. Mechanic
The problem is Bent brake disk's, Replace the brake disks to solve the problem.
Jack up the car, Take wheel off using a 17MM socket then remove the two bolts on rear of calliper then the two bolts on the calliper frame, Move them out of the way then Remove the small clip in one of the wheel nuts you will see it and remove the disk and replace, Do the same for other side and noise will have stopped.
Jul 09, 2010 | 2006 Ford Five Hundred
Marin Muirwoods 29er Hybrid Bike  2009 Closeout Logo
566 people viewed this question
Top Marin Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a Marin Rock and Ice Climbing Expert? Answer questions, earn points and help others
