Question about Panasonic Televison & Video
47 inch HD projection...3 flashes - Panasonic Televison & Video
  • 2 more comments
  • macjedi Aug 04, 2008
    PT47WX42X
  • macjedi Aug 05, 2008
    Ok ,I found the link to replace the IC's. Now i want to know about the resisters that people keep mentioning that may need replacement. Also,should i remove the high voltage wire or not?
    Also what should i be paying for the new IC's online?
    Nice work guys/ Thanks and regards. I'm gonna do it.
  • macjedi Aug 06, 2008
    Ok, One more thing.How do you remove those blasted white clips that hold the two circuit boards together.
    4 clips
  • Panasonic Master
  • 8,617 Answers
Whats the model number of your set. as different models have different meanings for a 3 flash error code. Please respond to this same post.
Posted on Aug 04, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Aug 04, 2008
    Thats the error code for the convergence ICs. Your model uses two STK392-110 Convergence ICs. Replace both of them. You can get replacment ICs with free instalation instructions with pictures at the following link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Aug 05, 2008
    You wont need to remove the high voltage wire as the Ics are located on the signal board which is on the far left looking in the back of the set. The resistors are six 2.2 ohm 2watt resistors R7048, 7049, 7050, 7053. 7056 and R7059 all 2.2 ohm 2 watts.
    Careful if you see ICs less than 15.00 as they are not worth getting. The site I posted have origional Ics and I use theirs in all my repair jobs.
  • Sonny Berry
    Let me know how you make out
  • Sonny Berry
    Sonny Berry Aug 07, 2008
    They stay attached to the board on the left and seperate from the board on the right like a hinge just pop them loose on the right side.
Red power light blinks, no picture. will not turn on Panasonic 47 inch rear projection
You would need to count the blinks as that is a error code-----3 or 5 blinks are the most common.
Let me know if I can help.
Aug 08, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic 47 inch rear view projector is hdtv ready, what do I need to buy to recieve pictures in HD
You should be able to receive the HD signal from your cable company. If you are still receiving your signal over the air, then you can buy an HD tuner. I found mine at Best Buy for $179 a few years ago. It will come with component outputs which is the HD signal.
I'm using my 70's vintage antenna on my house to receive the 3 local channels in HD.
Good Luck,
Jan 19, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Have a 46 inch panasonic projection tv hd
Sounds like the tech looking at it wasnt sure what was wrong. Whats the set do when you press power? Does the led blink? If so how many blinks is it blinking? I will try to assist you.
Feb 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
