Our LP Buck Stove will suddenly not lite. The pilot is lit. To start the stove, we just push the ON button and the fire lights, it stopped lighting without warning yesterday. Any ideas what is wrong? I don't know how old this is or the model number. Thanks.
    Brigadier General:
  • 4,736 Answers
If I understand it correctly, the pilot light will light and burn, but when you turn the Control Knob to the ON position either the burner won't light? My question is, doe the pilot stay lit or does it go out, when you do this.Also, is this a Vented or Vent-free Gas log Stove?
If it's vent-free, the Oxygen Depletion Sensor (ODS) which is part of the Pilot needs cleaning. As, it may be clogged with dust, lint & pet hair and it's sensing that there is not enough oxygen for safe combustion. The other issue tis relative to the pilot assembly, is whether this unit has a millivolt control valve and the Thermopile has failed. The Thermopile controls the opening and closing of the gas valve when you turn the Control Knob or ON/OFF switch to the ON position.
If it's a Vented unit, the same thing applies to the Thermopile.
It would also be wise to check the amount of gas you have in your tank. It may be to low to sustain combustion of the burner(s), but has just enough to keep the pilot burning.
Hope this helps you to Troubleshoot the problem. If it does please leave me a positive approval.
Thanks!
Posted on Mar 26, 2011
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
I want to light the pilot light for the oven
How old is the stove-- for most ovens these days have electric Glow Ignitors-
Are you sure yours has a gas pilot?
If so-- there has to be a way of pushing in a 'pilot' button, to get the gas to start,
and there has to be a hole or area you can get to the gas burner/pilot, with a match, at the time you are pushing in on the Pilot lite
Let us know what you find--
Mack B
Jan 20, 2011 | Ovens
FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot light
When you smell gas...is it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gas meter was changed upon relighting,top burners pilots are on but oven not
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
Apr 10, 2008 | Garland H283 Gas Kitchen Range
Heating & Cooling Logo
293 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
