Question about GE Refrigerators
The refrigerator is making a constant clicking noise and the temperature controls are disappearing from the display. When you click on the control the temperature shows -47 degrees for both refrigerator and freezer. This happens several times a day.
    Scholar:
  • 116 Answers
Hi my name is Sean, I work for GE, this is a bad main control board. It is located in the rear of the unit behind an access panel about 10X6 inches big. The board usually costs 175-200.00 to buy. If you have installed 300-400. If you need any further assistance let me know.
Posted on Mar 26, 2011
Testimonial: "Thanks Sean!"
Chimes constantly. How do you turn them off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
Feb 10, 2014 | Maytag Refrigerators
Door of the refrigerator has been slightly open for 7 days the refrigerator works **** make a lot of noise
You will have to do a manual defrost to clear that up. There is just no way the standard defrost cycle can keep up with that volume of moisture. The noise you hear is usually the circulation fan rubbing against the frost buildup. You may also perform several defrost cycles manually by locating your defrost timer and spinning it until it clicks. This is usually located in a hole near your temperature controls, and can be turned with a medium sized screwdriver. When the defrost cycle completes you will here the compressor kick back on, this is your cue to restart the defrost again. Do this until the fan noise disappears.
Mar 13, 2010 | Refrigerators
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
My GE Fridge is making a clicking noise and Digital display out
Replace the mother board. (part # WR55X10942 )
Aug 21, 2009 | Refrigerators
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
Refrigerators Logo
319 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
