Question about Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170
How do I reset my DTC Digital Timer for the Vista Outdoor Lighting sytem?
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Hamilton
The reset button is small round button with R
I assume you push reset button with toothpick
The manual is unclear if you need to press another button at same time to reset timer
Manual says: If needed, pressing "R" will cancel the current setting,
pressing "R" a second time will undo the change.
Posted on Mar 27, 2011
How do I set a Outdoor Timer Model 23ULD/3AOType 3R
Copy following link to identify timer, and see instruction manuals for each type:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 08, 2013 | Woods Outdoor Lighting Timer
How to open to repair Woods 24 Hour Digital Outdoor Timer with Photocell Mfr # 13660
1) Copy following link to identify timer, and select replacement if needed.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
2) There is no reset button on this type of timer.
Nor is there a repair manual for $16 timers.
Generally people buy another timer since the timing chips and parts are delicate, easily damaged by power surge, and often quit working before 1 year warranty expires, and usually last a few years before no longer functioning. The photoeye sensor is often a failure point.
3) Check outlet for 80% rated voltage.
Check timer on different outlet.
Use circuit analyzer and test outlet for correct polarity and grounding.
Test and replace GFCI outlets as needed.
Dec 01, 2012 | Woods Outdoor Lighting Timer
MDL Corp - Manual Timer 301-0004 (Outdoor Lighting)
Timer brand and model are not identified.
Some timers are rated for incandescent light bulbs, while other timers are rated for CFL incandescent and all types of loads.
Open following links to help identify in-wall timer:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
May 28, 2012 | Home
I need programming instructions for my intermatic outdoor lighting timer
Hi Jeanne,
Here's a page with detailed instructions and pictures - that will guide you through programming. I hope this helps & good luck!
Nov 09, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer and the time keeps running slow. Does the unit need sunlight to run the clock or do I need to change the internal battery? I have...
1) No the timer has internal rechargeable battery.
Battery is not replaceable.
2) I test timers, 4-6% arrive defective. Most go bad within few years. Some last long time.
3) If you set timer to turn ON at dusk, and turn OFF 2 hours later, then reflected light or car lights can give photoeye feedback so timer thinks it's light. Timer turns off and resets. I don't know if this information applies to you.
4) Link shows timer and manual for Westinghouse
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Jan 13, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Instructions manual for the Woods outdoor photoelectric lighting timer WD -49103
http://www.ccixpress.com/cci/Marketing/Woods_US_Timer_Instructions/TM_13660_InstrMan.pdf
Nov 15, 2009 | Woods INDUSTRIES 13660 OUTDOOR DIGITAL...
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170 Logo
1,022 people viewed this question
Top Vista Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Vista Hardware and Accessory Expert? Answer questions, earn points and help others
