Question about LG LMV1650ST Microwave Oven
Hello, I can't locate my lg microwave manual and need to find where the fuse is
    Sergeant:
  • 192 Answers
You can find your manual HERE
The parts breakdown can be found HERE
Posted on Mar 26, 2011
Lg microwave fuse location
Fuses are normally internal on Microwaves and opening the cabinet exposes dangerous voltages, even when disconnected.
The fuses used are 'Ceramic' and look like this.
ceramicfuse-3tkv02zfhnnile0ve5y4fcys-1-0.jpg However, just replacing it may not fix the problem, if you have a shorted component inside, it will need to be repaired by a competent shop/technician.
May 15, 2017 | LG Microwave Ovens
I need a manual book for the LG Wavedome microwave
Hello, ideally we need the exact model number of your Oven however the following is a link to the LG website where you can download a manual for a WAVEDOME
http://www.lg.com/us/support-product/lg-MS-152XC
Jul 30, 2012 | LG MC7849HS Microwave Oven
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
Ss25 microwave no power fuse in plug ok, where is internal fuse.
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Won't heat food on any setting. Could it be a fuse? Where would it be located? Don't have a manual.
Fuse will be inside the oven.And with replacing fuse ,you need to check the cause of blowing the fuse.Check the capacitor and transformer (physically).If they look deformed .Then change it followed by the fuse.
Thanks
Please rate my work
Sep 17, 2011 | Daewoo KOR-630A Microwave Oven
My LMV2053SB microwave won't turn on.
It is located on the top of the chassis under the outer cover.
You will need to remove the oven from the wall and remove the outer cover to get to it.
Having the installation instructions really helps in this case, but if for some reason you don't have yours,
L.G. / Goldstar manuals can be downloaded here.
If yours' is not available there,
call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
We have the service manual and parts manual for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it
The oven cavity thermostat is part # 6930W1A003D and it can be ordered at the Sears parts site.
Dec 07, 2008 | LG Over-the-Range Microwave
LG ms-304ez microwave
I would suspect the fuse or the thermostat.
The fuse should be located on a filter board near the back of the unit where the cord comes in.
The thermostat should be located on the left rear corner of the chassis above the cooking cavity.
We have two service manuals for this type of model and have uploaded them to our site here and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Since these are not exactly the same models as yours, the part number for the thermostat may not be the same. You should verify them with the distributor.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Formore Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
L.G. / Goldstar owner's manuals can be downloaded here.
Oct 30, 2008 | Microwave Ovens
Microwave has no power
I'd say the thermostat and/or fuse are blown. I just hope the magnetron survived.
I don't have that exact model's service manual but ones before and after only used one thermostat, similar to the drawing below.
They also have a fuse, usually located in an inline fuse holder connected to the power cord inside.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Aug 21, 2008 | Goldstar MV-1515 Microwave Oven
LG LMV1650ST Microwave Oven Logo
153 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
