Question about Powermatic 1791227K Model 64 10" Artisan Left Tilt Table Saw with 30" Accu Fence System
What is the difference between a powermatic 64 table saw and a 64A table saw?
SOURCE: Need a rocker switch for
If you want to buy a new one, the Grizzly G1022 Table saw is an exact replica of the PM#63. A owners manual and parts list is available at their website. Grizzly.com
Posted on Apr 12, 2009
SOURCE: My Powermatic 66 table saw won't start.
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Posted on Jul 29, 2009
  • 70 Answers
SOURCE: vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Posted on Aug 07, 2009
SOURCE: Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Posted on Aug 23, 2009
  • 5603 Answers
SOURCE: I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Posted on Oct 24, 2009
How do you set tension on overlocker
I have no idea what an overlocker is. Help me out.
Aug 31, 2014 | Powermatic 1791227K Model 64 10" Artisan...
Difficulty raising and lowering the blade on Delta rockwell10" unisaw 34-450
Ok, basic question...is the lock engaged? It is the small knob at the center of the adjustment wheel. Is it possible the screw has been galled?
Here is the manual- http://content.powermatic.com/manuals/1791227K_man.pdf
May 27, 2014 | Powermatic 1791227K Model 64 10" Artisan...
Table saw won't start
You can only tell by using a continuity tester or a multimeter and some troubleshooting techniques.
Nov 10, 2013 | Powermatic 1791227K Model 64 10" Artisan...
Truing the fence on a Powermatic 66 table saw
There should be some screws on the bottom side of the fence that allow you to make adjustments. Loosen then slightly then set the fence to 90 degrees & then tighten them.
Dec 27, 2017 | Powermatic 1791227K Model 64 10" Artisan...
In replacing the 2 power cords can I buy a stock cord from Home Depot or do I need to order a Powermatic relacement cord.
you can buy a cord from anywhere as long as it is the same wire guage and approx diameter that you have now.
Mar 02, 2011 | Powermatic 1791228K 64 Left Tilt with 50"...
Aline table to blade
align blade and fence to mitre slot.
Jan 26, 2010 | Powermatic 1791227K Model 64 10" Artisan...
Powermatic 64a tablesaw- won't start. I think it is the switch. Took it off full of sawdust...how do I test it?
do this with the power off. take the leads off of the switch and connect them together. Then plug the saw back in. If it runs, the switch is bad. Any small toggle switch will work as a replacement
Jan 05, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Need a rocker switch for a Powermatic 63 A Artisan table saw part number 6285322
Jan 03, 2009 | Powermatic 1791227K Model 64 10" Artisan...
Powermatic 1791227K Model 64 10" Artisan Left Tilt Table Saw with 30" Accu Fence System Logo
153 people viewed this question
Top Powermatic Saws Experts
80stech
Dennis Key
Dennis Key
Ivan
Ivan
Level 1 Expert
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
