Question about Panasonic Lumix DMC-LX2 Digital Camera
Lumix dmc lx2
Black screen
  • anaba Sep 15, 2008
    Hi, I have the same problem. However, the camera sometimes wakes up - and then it works mostly fine for the next couple of hours (black screen appearing only sometimes). What's the problem? Is there a service mode for LX2 which could point to the problem?
    Scholar:
  • 83 Answers
Does the menu show up on the screen, or is it totally black?
Does the camera take pictures and behaves as normal (apart from black screen ;)?
If the menu shows up then I'm afraid it's most probably something serious- like dead CCD or failed shutter (probably the latter-LX2s are not famous for failing CCDs). Failed shutter is easy to identify. You would normally hear a faint mechanical"click" when taking a picture (make sure you disable sounds in your camera). If you can't hear anything then the shutter might be dead. In cases like this I normally suggest getting a donor camera from ebay and replacing the lens (the shutter assembly is inside the lens but it's much easier to replace the whole lens).
Good luck,
Raf
Posted on Nov 05, 2009
  • 407 Answers
The camera has been set to economy mode, so after so many minutes of inactivity it will turn the screen off - You can change this in menue settings camera.
Posted on May 12, 2009
SOURCE:
SOURCE: While I was using it,
I inserted a fresh battery from a similar camera. Turns out I hadn't been watching the battery level indicator. So: imaginary problem
Posted on Oct 09, 2008
  • 148 Answers
SOURCE: need to get hold of the instructions
hello g_wood22. here is website for downloading your digital camera manual.
http://www.retrevo.com/support/Panasonic-DMC-LX2-Digital-Cameras-manual/id/619ag806/t/2/
please rate me and write me back if this solution is was helpful to you.
Posted on Apr 05, 2009
  • 11967 Answers
SOURCE: I have a Lumix DMC-LX2. Display message close and reopoen camera.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
  • 30 Answers
SOURCE: stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
Posted on Jan 13, 2010
  • 11967 Answers
SOURCE: I dropped my lumix dmc-lx2
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Nov 29, 2010
Broken screen on panasonic lumix DMC-LX2. Have repair???
Hello I got one with broken lens (grinding cogs) : otherwise P'fect could we organise something ?Pete Cooper.
Aug 12, 2012 | Panasonic Lumix DMC-LX2 Digital Camera
I have a gifted panasonic lumix DMC-LX2 but the settings is in french.How do i change the language to english
Press the MENU/SET button. Press cursor-left. Use cursor-up/down to select the wrench icon and press cursor-right. Use cursor-up/down to select the talking-head icon. Use cursor-up/down to select the desired language and press MENU/SET.
Jun 25, 2012 | Panasonic Lumix DMC-LX2 Digital Camera
My lumix camera will come on, but the display for the pifture is black, how do i fix this
I think most of these questions about black LCD's and black pictures relate to a stuck shutter. My Lumix LX2 has this. The screen is black and so are the pictures. On looking at the shutter through a magnifying glass I took a shot and I saw that the iris works fine, but the shutter did not open. I am sending the camera for repair at a reasonable rate from Clearer images here in the UK.This is the email: [email protected] Time will tell won't it?
Jan 13, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
Just finished charging the battery of my Panasonic DMC-LX2. Attempted to turn on my camera but it doesn't work. The battery is completely charged and this has never happened before.
Hello....I have the same issue with my Panasonic Lumix DMC-FS5 camera we bought 3 years ago. All of a sudden the camera doesn't work. I have had many cameras and I have never seen this before. I will think twice about buying a panasonic again.
Dec 12, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
Stuck lens on on lumix dmc-LX2
Jan 13, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
No preview image. Black screen LCD
The problem is not with the LCD or the camera - You have got it set to ecomony / power save mode. Fixable through camera settings.
May 10, 2009 | Panasonic Lumix DMC-LX2 Digital Camera
Need to get hold of the instructions
Apr 05, 2009 | Panasonic Cameras
SD card download to PC
You can download the software CD from Panasonic website.
You should however, be able to transfer images to your computer using a USB cable, and exploring the device in my computer.
Nov 02, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Black Screen - locked shutter?
Same problem here! I just had my 1.5 year old camera checked at a local service, and I was told that the shutter is not working correctly, and that it looks like a factory defect. Anybody knows if Panasonic offers replacement/servicing out of warranty for such issues (and how/where to send)? ...I am not happy at all with such an expensive and supposedly high quality compact camera die so quickly. Thanks a lot.
May 15, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Panasonic Lumix DMC-LX2 error message
Try removing the card and re-inserting it was an intermittent issue with one card for me,the problem has now disappeared
Mar 17, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Panasonic Lumix  DMC-LX2 Digital Camera Logo
437 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
