3 floor house could it work if the router is installed in the 2nd floor of our house
  • 90 Answers
Yes. It will work.
Posted on Mar 26, 2011
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
Can I add a 2nd wireless router at another location?
Your best bet is to use a wireless extender, this will extend the range.
Google search for these devices.
Feb 01, 2010 | D-Link AirPlus DI-614+ Wireless Router
We have a Belin N150 installed on the ground floor of a 3 storey house. When I work from home with my laptop on the 1st floor, using a remote access token, the screen continuously freezes and I am...
Go to pc world or wherever and buy a belkin wireless range extender, then install it somewhere in the middle. They are easy to set up, follow the instructions and they work every time. Watch out for thick brick walls or anything metal, that will interfere with signals.
Nov 11, 2009 | Belkin (F5D5231-4) Router
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Laptop wireless computer on 2nd floor. Modem and
To test it whether the signal is too weak or not, take your laptop closer to where the router is and try to connect that way. If it does connect then the wireless signal from the router is too weak in which case get a range expander or purchase a router with extended range.
Mar 23, 2009 | NetGear WGR614 Wireless Router
Actiontec Model GT701-WRU signal failure when on line when using notebook in other parts of the house no signal to desk top pc on third floor of house signal to low disconects from the net can you...
That is not a configuration problem, that is a signal problem.
It means that the signal does not have enough power to reach all part of the house.
A way to fix this is by installing a repeater, like this one Linksys WRE54G-UK 54Mbps Wireless Range Expander
Your router is a G, not very powerful. An alternative is buying a more powerful N router, like the ones below.
www.newertech.com/products/router.php
BELKIN B5DUK060 Router + WiFi 802.11n USB
Se the comparison diagram
Oct 14, 2008 | NetGear WGR614 Wireless Router
Connecting
It is is best to setup the router on the lower level or the main level *** it will transmit the signal up and broaden as it goes up. hope this helps.
Sep 21, 2008 | NetGear MR814 Wireless Router
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Linksys Router Range
I have two wireless b routers in my home. Its not really a question of the square footage but what obstacles are in the way. My son purchased a Wii and the router would not reach it reliably. I thought about the path the signal had to go from point a to point b and it was directly through a furnace, a fuse panel and a bathroom mirror so I thought that was not fair even though it was only a few rooms away on the same floor. I purchased a wireless access point (router number 2) and put that up higher in a room closer that was easy to run a wire to and plug in. This gave me the upper hand by missing the two large metal objects. I am still having more trouble getting this signal to reliably work than I do beaming my signal across about 800 feet of open field to my mother in laws house where she has a good signal with a wireless card. We learned to put the computer right on a table in the window so I can actually see line of site from my loft office to her 1st floor office and it works. I was about to try all those kinds of antenna's that you might have become interested in.
My advice, don't mix brands I made the system all Linksys and this helped more, get the router up high in the house rather than on some table or the floor, think about the obstacles and you will make progress like I did.
I don't have G but B but I think this will help. Oh yeah, for about $10 I purchased the longer antenna's from Radio Shack that are a steal. This also was part of the recipe for success. I have no cobbled up antennas, but honestly my signal is weak two floor down from the loft in the basement. If I was starting over it would be a router in the middle of the house in the basement perhaps up high and in the middle of the second floor up high with a nice shelf and an outlet so I could get to it easy and see if from a distance without a ladder. Real life: find some shelf you already have, run an extension cord, buy a long network wire already terminated and put the router up there to try it out before you install it for good. I've could go on with lessons but this is a start.
Dec 03, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
