Question about Frigidaire Affinity ATF7000E Front Load Washer
Leaking door seal - Frigidaire Affinity ATF7000E Front Load Washer
  • 2,510 Answers
The door seal on a front loader is usually part of the boot that seals the drum from the front panel of the machine. It is held on over lips on the door and outer drum. Pull the seal away from the front panel and it should reveal the lip, now pull the seal off the lip working around the whole area. Push the seal into the drum and work it off that lip too. Replacement is the opposite of the removal and just requires a little patience. (Take you old seal with when purchasing a new one to make sure you get the right part).
Posted on Mar 26, 2011
Fisher and Paykel washing machine model WL80T65D leaking water on filling
were is the leak if leaking at door a new door seal check no clothing trapped in door if you run your finger over loose rubber part of seal at bottom and your finger goes through the seal is perished new door seal i am afraid
Dec 10, 2016 | Fisher and Paykel Washing Machines
I have changed to door seas but still leaking, what other seals are there that could be leaking
If the door seals are not replaced _exactly_ right, it will leak like a sieve. Otherwise, the water control valve is located right up front and may be leaking, and tricking you into thinking it was the door seals.
Apr 06, 2016 | Dishwashers
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
Dishwasher leaking at lower door seal
Possible that the door seal has failed and there is leak when the pressure spraying takes place. Please check the seal and replace, click for tips to replace: door seal
Jan 02, 2013 | Dishwashers
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
Leaking dishwasher
HI, i would inspect the door seal. make sure there isn't any foreign objects that are getting stuck in between the door seal and tub housing. if the seal is clear of any objects(small objects), this will confirm door seal failuer.
simply replace the bad door seal in this case.
Jun 16, 2009 | Kenmore Dishwashers
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
360 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
