Question about Health & Beauty
My touch screen window does not work properly. if one key is pressed then another key displayed. sir please give a suggestion
Your touch screen grid is got damaged.you have to change the screen
Posted on Mar 26, 2011
Funtion keys dont work right with windows 8.1
Are you simultaneously pressing the Fn key while pressing the F1 thru F12 keys?
Mar 20, 2014 | Lenovo G500s Touch 59378929 Laptop...
Getting bored from Nokia C5-03 touch screen Hang problems & display related problems
Hi @Jayeshsinh DO this steps:
>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
Oct 29, 2017 | Nokia C503 Cell Phone
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
Samsung Star GT S 5603. Touch screen of my phone donesnot work mostly key pad does not work all other touch functio work properly only having problem in my touchscreen keypad. Can u plz tell me the...
sir you give to the samsung service center for servicing the touch sencor device [or] they will re-install the new software for your phone...............
Nov 26, 2010 | Samsung Star GT-S5233 Cell Phone
My touch screen does not operate properly. When I attempt to press/touch a character another character appears. Example when touching 1, 4 apperars on the screen. How can I correct or reset the touch...
The touchscreen portion of your display is severely out of alignment. Try finding the utility(use hardware keys) to align the display (under settings). Try to align it. If it is too far out of range, it will kick out your "presses". If this happens, you *might* be able to try a reset, but it likely will not work. Otherwise, your only recourse will be replacement or repair.
Jun 23, 2010 | Samsung Behold Cell Phone
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
May 25, 2009 | Garmin Nuvi 660 GPS Receiver
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
