Question about Dell Latitude D830 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/5... PC Desktop
BLACK SCREEN; DST SHOWS DISCRIBED FAILURE; SAFE MODE POSSIBLE
  • Allan Dale Dela Cruz
    Allan Dale Dela Cruz Mar 26, 2011
    Its either that the disk has a failure, do you happen to have the error code? what operating system is it? have you tried safe mode? do you have a chat?
    Guru:
  • 433 Answers
Vega card make aproblem re-instal windows
Posted on Mar 26, 2011
Startup
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Jul 16, 2013 | Acer Aspire 5050-3242 Notebook
My acer aspire one laptop 532h-2db blank screen . help me pls.
If there is still light on it there are two possible points of failure. But we need to isolate first if it is a hardware or a OS issue. To do this you need to try to boot to the BIOS.
> Restart the computer and tap on F2 continously until you see a setup screen or the screen saying loading system setup.
If is goes to the system setup, then the issue is with the OS. Try to boot to safe mode.
Restart the computer and then keep on tapping F8 until you get a black screen with white writings on it that says safe mode, safe mode with networking. Choose Safe Mode. If this works, you just need to reinstall the video driver.
If booting to the BIOS does not work, then the problem is hardware related.
Try to connect an external monitor and then press Fn + F5, if the screen shows up on the external monitor then you have a problem with the LCD screen of your portable. You need to have it replaced.
If It does not show up, you need to have the video card replaced on the laptop which is embedded on the motherboard which pretty much is the whole electronic component underneath your keyboard.
Unfortunately this means it will be more economical to buy a new laptop. 1.
Jun 28, 2011 | Computers & Internet
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
We have 2 DZS400 digital tork timers. unfortumately when DST days were changed we have not been able to use the automated dst transition and must manually change the clocks twice each year. is there a way...
DZS400 product descriptor shows DST, and many other programming options:
1) This might help or not:
You can modify DST start & end times > Press MODE until dSt shows > Press MONTH, DATE, DAY to modify start times, and then press ENTER. (or press DEL and ENTER to delete) > Press MONTH, DAY, DATE to modify end times, and the press ENTER > press MODE to return to AUTO.
2) According to DZS400 product descriptor "The controller has 365 day holiday capabilities with 24 single dates" ... if above solution doesn't work, the 24 single dates might provide enough days to fill in programming gaps in the DST. Your manual should have programming steps.
Sep 18, 2010 | TORK Hardware & Accessories
How do I reset my Intermatic wall switch timer?
If CR2 battery went dead or if battery removed more than 1 minute, then time-date disappeared, but programming stays in timer indefinitely even if power is off.
To reset time-date. (From Section 5 in manual)
Press MODE until screen displays SET UP
> Press ON-OFF until HOUR shows ... use + key to change hour
> Press ON-OFF until MINute shows ... use + key to change minute
> Repeat same sequence for Year, Month, Day
> Press ON-OFF until DST daylight savings time ... use + key ... choose AUTO if area has DST ... choose MANual if areas does not have DST
> Press MODE to exit and save settings
Other programming steps are long.
Manual shows programming steps:
http://waterheatertimer.org/Intermatic-st01c.pdf
Walk through programming steps:
http://waterheatertimer.org/ST01C-program.html
Sep 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a dell inspiron lap top with window's vista. There is a problem with it. Even when I turn it on with safe mode it goes to the log in screen, then says welcome, and then it goes to a black screen...
Usually what happens with my Dell Inspiron desktop, even on safe mode it goes to the logon screen. I have never experienced that with my Dell Inspiron 1318. When you log in and it shows you the black screen, try pressing the function buttons. Try F8 or F12. You should be able to start the computer in Safe Mode. If possible, enter Safe Mode with Networking so that you are able to search the web. If you don't mind me asking, why is it that you need safe mode? Is it a virus?
Aug 08, 2010 | Dell Inspiron 1318 Notebook
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Oct 26, 2009 | IBM ThinkPad T60 Notebook
HP G7000 Desktop failure?
hi,
When the hp logo comes keep taping F8 button.the advance options will come then select safe mode and start in safe mode by loging in in administrator.
If you made any changes recently restore the system to aback date by progarames>accessories>system tools>system restore and by selecting a date given in bold nearto the date when issue arrived.
The issue should be resolved.
Feb 05, 2009 | HP Computers & Internet
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Latitude D830 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/5... PC Desktop Logo
23 people viewed this question
Alun Cox
