Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My cabrio washer has change that got under the tub how do i get it out what do i have to remove
  • Samuel Charles Spriggs Mar 26, 2011
    Is the change under the tub or just under the agitator ?
    Charlie
  • Teri Nov 04, 2012
    Charlie, I had my washer fixed 6 months ago for washer eating a dime, I don't want to pay another $95 for a service call so with my husband out of town I a gave it a shot. I watched the u tube video on how to take off the the pump. To my suprise it wasn't there. But if you have the machine turned on its belly like the demonstration shows, right in between both pumps you will see a plastic molded "change purse". I tood off one of the clamps so I could reach my finger in there to find a dime. Both times it ate a dime, Its a pretty easy fix, I just needed to be persistant.
    Sergeant:
  • 192 Answers
Step by step instructions found HERE starting on page 4-9 on how to remove your basket.
It will take a minute to load the document.
Hope you get rich....:)
Posted on Mar 26, 2011
  • Whispis2
    Whispis2 Mar 26, 2011
    Also found here on page 4-9 as well.
    Just copy and paste the link in your browser.https://secured.whirlpool.com/Service/Sr...$FILE/8178583.pdf
My Whirlpool Cabrio Model #WTW6600SWO make loud noise when it doing it mean spin cycle have you think is wrong???
Posted on Jun 09, 2011
4 Suggested Answers
  • 4088 Answers
SOURCE: need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Posted on Oct 08, 2009
Testimonial: "Thank you so much. I had figured out how to unscrew agitator, but was affraid to pull 2 hard as I thought I might break it. Your 2 step method works"
jan mczeal
  • 632 Answers
SOURCE: How do I remove gravel underneath washer tub?
To access the washer:
  1. Use a putty knife about an inch wide.
  2. Push the putty knife on the sides to release the top panel and lid clips.
  3. Lift the top panel back towards the wall.
  4. Tape the lid so it does not fall back and chip.
  5. Remove the two 5/16 inch screws on the inside of the front panel. The top of the front panel will come towards you.
  6. Lift the front panel off the clips on the bottom and set aside.
  7. Pull the washer out from the wall and lift up the front to access the belt. Support it with a block of wood.
Posted on Aug 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Washer gives F50 error. I've taken top off and
Press pause cancel once and that should do it. If not the repair manual advises calling for service. Lets see what the F50 is...hold on...Motor stalled, rotor position sensor detects no motion from the tub, does basket move freely? If basket moves freely see test#3 in the repair manual HERE
The manual gives readings to verify and has a long detailed complicated set of IF's for this machine. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 12, 2010
6200 whirlpool cabrio, Ld error code. Usually, cancel, start corrects problems. Now seems like it won't spin. Tried unplugging and restarting, that also didn't work.
most likely a clogged pump drain find it below the drum usually under a plastic lid bottom left if not under the lower panel below the door
find the 3 screws and remove the cover panel and clean the pump by twisting the pump valve cover counter clockwise
WHIRLPOOL CABRIO WASHER ERROR LD The Cabrio Washer LD error code stands for Long Drain which means the control has recognized the water in the tub is not draining fast enough during the cycle.
  1. Make sure the pump and drain hose are clear of debris that would cause a blockage.
  2. Check the impeller on the drain pump and make sure its not wobbly or busted.
  3. Remove the tub hose from the pump to the tub and check it for blockage.
  4. Make sure the pump is running when and getting the proper voltage when it should be.
  5. If all the above checks out then replace the drain pump motor.
Feb 14, 2018 | Whirlpool Washing Machines
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Code f51
If its under the agitator, simply unscrew the top of the agitator, pull up the agitator and remove the Necklave. If its under the tub itself, you need to access it from underneath, which means you will need to take off the entire outside cover, starting with the top. Once you have removed the entire cover, then you will need to remove each piece that is blocking you from getting to the Necklave. This process is better done by an appliance repair person.
Jul 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Washer - tub damage on very top flange
water to hot,,,but your under warranty,,have them change tub ring,,
Jan 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loose change
the tub oo this machine just sits on apost, weight of the tub only thing holding down, you will needa putty knife adn insert it about 3 inches in from either side t o "pop" the top hold down clips, the main lid assy will the tip back wards, next remove the outer tub cover (10 or so clips holding around the outside of outer tub.) after that the inner basket should lift right up and out. reaasmble teh same way.. be carefull the outside if the inner basket is extremely sharp from all those holes
Mar 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
3,242 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
