Question about Whirlpool Refrigerators
Frig stops cooling. freezer on bottom. frig is running just not cooling. made in 2008. we clean it let it set for 24 hr it cools again. is there a defrost heater that we can turn on, to solve this problem.
    Scholar:
  • 116 Answers
Hi, this model i believe has a calrod heater, and those usually dont go bad very often, its more than likely a bad defrost thermostat or control board, the thermostat is located in the freezer behind the back panel on the evaporator, the control board if it has one is going to be up in the control panel by the the thermostat, if it doesnt have a control board it will have a timer, I would change the timer and the thermostat in that case. It is also possible you have a bad heater which is also located in the freezer behind the back panel, under the evaporator, If you know how to use a meter you check this heater with an ohm meter. Let me know if you need further assistance.
Sean
Posted on Mar 26, 2011
Samsung RS2630SH Side by Side Refrigerator not cooling down frig or freezer
Is the compressor running? If so, feel the discharge line is the line cold? If not the unit is probably out of Freon, which means it will have a leak somewhere in the system.
Aug 25, 2014 | Samsung RS2630SH Side by Side Refrigerator
Frig stopped working but freezer is good? Help... I am handy.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
Freezer has light frost in bak and frig is not cooling properly
Sounds like it is not defrosting . Either the defrost timer, heater or thermostat. Leave the bottom door open for 24 hours and will probably work again for about a week till repaired.
Oct 27, 2010 | Amana ABB2227DE Bottom Freezer...
Kitchen Aid refrigerator, model KBFA25ERWH01 – French Door / Bottom Freezer. Not cooling both frig & free. Unplugged to the compressor cool down. Unplugged and removed the capacitor and relay (DID NOT...
If the refrigerator try's to start and then shuts down, something is going the burn up. If it doesn't run, call a repair service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | KitchenAid Refrigerators
Freezer freezes but frig wont cool amana with freezer on the bottom
I couldn't find a repairman so I pulled the big thing away from the wall, took off the bottom front plate and the bottom rear plate and unplugged the big beast. Then using a refrigerator brush and a vacuum I carefully cleaned all the dustballs from the coils on the bottom. Then plugged it back in and in about 3 hours it was cooling normally again on a "4" setting.
Jul 13, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Aug 26, 2007 | Refrigerators
Refrigerators Logo
78 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
