Question about Cisco Linksys Wirelessn Router Black (e1000)
How many feet could it connect - Cisco Linksys Wirelessn Router Black (e1000)
    Sergeant:
  • 231 Answers
100 yards is the typical range for the Linksys router give or take however, there are wireless antenna's that allow you to boost your wifi signal. Amazon.com has the antenna's available.
Posted on Mar 26, 2011
  • 90 Answers
It depends. Eye of site it could connect 50 to 150 at the max
Electric start not working
Please check the continuity from swicth to relay is ok. Make sure that wire not short to ground. Normally relay has 4 feets which 2 feet connect to big wire and another 2 connected to small wires.. to check the relay connect the small wires to 12v terminal battery and click sound will appear. At the same time test the continuity of the another 2 feets should be less than 2ohm..
Nov 08, 2013 | 2008 Yamaha WR250R
Sewer lines
Sewer lines can be 3 feet deep to 25-50 feet deep depending on location.
http://waterheatertimer.org/Sewer-construction.html
Residential sewer lines are generally 3-5 feet on flat yard depending on local code.
Deeper lines if house is on hill etc.
Local permit board might have drawings and general elevation.
Locate manhole near house to determine which direction main sewer line runs. Main sewer line will be 20 or more feet deep. However homes do not connect at that depth. Homes connect at shallower depth on a branch pipe, and then branch drains into the main sewer line.
Jun 01, 2013 | Water Heaters
Loose antenna connection in radio
I could probaly help you better if you posted a picture of the back but the screws are alway concealed in battery compartments and behind stickers or rubber feet. The rubber feet are usually just pressed in but can easily be re-glued.
Jan 20, 2013 | Audio Players & Recorders
I SET UP RAUTER AND WORKS JUST FINE CLOSE TO THE MODEM BUT AS SOON AS I CONNECT THIS 120 FEET, IT DOES NOT WORK AT ALL. THANKS
This has happened to me many times. There are a few ways to get around this.
120 Feet is well within the range of the device. However that range is affected by a wide range of factors.
  • Walls - The signal will have a hard time penetrating some types of construction (e.g. Concrete, Lathe and Plaster)
  • Obstructions - Other things can also block the signal. Freezers, speakers, electronics, extensive wiring.
  • Environment - Some areas are more or less wireless dead zones. Nearby airports, radio antenna or other broadcasting equipment can interfere with the wireless signal.
If your 120 feet include 8 lathe and plaster walls, with a ham radio and a walk in freezer; you want to just get a nice long cable instead of proceeding with my further advice. However if there are only a couple of drywall walls and no blockages proceed.
  1. Try adjusting the location of the router. Often just moving the router to a high shelf or over a few feet can solve this type of issue.
  2. Can you connect at any range between close and 120 feet? Some testing could help identify the source of your signal loss.
  3. Try to build an antenna?
  4. Get a cable
At home I use a cable even though I'm mere feet away from my wireless router. I play online games and the wireless signal regularly experiences fluctuations in connectivity. This represents just how delicate the wireless connection really is. Imagine the invisible waves trying to penetrate your 120 feet and look for anything that might obstruct.
Mar 07, 2011 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
What type of HDMI cable do I need to connect my DVD player to my HD Sanyo TV?
Make sure DVD player and TV have HDMI ports at back to hook with HDMI cable.
HDMI cable has standard plugs on both ends and its length can be different like 3 feet, 6 feet or 10 feet. Click HERE to buy required length HDMI cable.
Oct 23, 2009 | Philips Televison & Video
Losing wireless Connection
No solution known to fix this. Internal the software tries to refind itself.
In Linksys software there are two separate programs running. The video is sent to the wireless router and recorded on your computer. Whether it is alive or not and can be configured is a different program. That program requires the wireless camera be literally just a few feet from the wireless router. Say 5 feet or less. One configured you can move the camera to well over 100 feet from router fine.
But eventually it will lose connection and you have physically move camera back.
This is a major flaw of this system and why it won't work for a real application
Jun 20, 2009 | Linksys Wireless-G WVC54GC Network Camera
Bad range
Actually, you are using a Class Bluetooth adapter which can go up to Up to 330 feet (100 meters) wireless working distance. It is compatible with Class 2 (33 feet/10 meters) and 3 (3.3 feet/1meter) Bluetooth devices but it will follow the short range. Your moto h375 headset is a Class 3 device so it should go only go up to 3.3 feet indoor (line of sight).
May 09, 2009 | IOGear GBU321 Bluetooth Wireless Adapter
Strong signal but no connectivity
ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Oct 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Cisco Linksys Wirelessn Router  Black (e1000) Logo
83 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
