Hi, I have to replace the capacitor (35 +2 microfarad) for my LG 1 ton, split Air Conditioner. The LG service guys had told that this model is nomore available with them. They tried some alternatives, but did not work out. So, in India, where would i get the exact capacitor for the LG 1 ton, split AC
    President:
  • 1,515 Answers
Are you sure the capacitor is faulty? You can go up in U,F's but not down and if it is the capacitor it will work. For instance, you can use a 40x5. The larger number is to start the compressor ad the lower is for the outdoor fan motor. I know nothing of India, but if you have any appliance parts houses, they will have them, or can order one for you. A capacitor for that unit should be easy to find if you have parts places for appliance's there. Good Luck, and keep me posted. You can order on on the Internet from the States also. They are inexpensive, the shipping charges may cost the most. Have it checked out to make sure is is faulty. If it is swollen or deformed, or leaking oil, its bad. If not, take it to a repair place for appliance parts and check it for dead shorts or open windings..
Shastalaker7
A/C,& Heating Contractor.
Posted on Mar 26, 2011
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
WHICH UF RUNNING CAPACITOR WILL BE OK FOR 1.5 TON SPLIT AC?
You need to post/research the model # and brand of compressor. The fan motor will state the UF/capacitor rating. There's absolutely no answer to that ? without more info. Sorry. And sometimes that info is only available from the manufacturer. Most refrigeration parts houses can look it up.
Aug 08, 2015 | LG LS-L1210CL Mini Split Air Conditioner
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
May 06, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi, I replaced a comp on my Goldstar GA 1260 model split, the old capacitor had 3 contact points, the new one has got only 2? Can anyone help out?
Yes, your old one was probably a dual capacitor. The middle terminal was common to the compressor capacitor and fan capacitor. The new capacitor if for the compressor only. You will need to reuse the fan side of the capacitor or purchase a separate capacitor for the fan. I hope this helps.
Mar 19, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Pac 35 split air conditioner not cooling
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
May 08, 2009 | DeLonghi Heating & Cooling
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
