Question about Thomson Computers & Internet
Wireless card inserted as directed, power supply turned on and card does not light up
  • 90 Answers
Check with vendor once again
Posted on Mar 26, 2011
My screen is flashing light to dark all the time. .
Unplug your power supply, all peripherals, any USB's and SD cards, then disconnect the battery. Let sit for at least 1 minute. If laptop will run without battery inserted, just plug in the external power supply and turn on. If problem is gone. Turn off, reinsert battery, reconnect your peripherals and restart. Good luck!
Dec 21, 2014 | Computers & Internet
I believe I may have inserted the wireless internet hardware backwards. Could this cause my Desktop to no longer power on? D=
The USB wireless adapter can only go in the port one way or PCI-E wireless card can only go in the slot one way. If you forced either one in then there's a great chance you did. Of course there's a chance your power supply is dead, but if you try powering up and the power supply fan spins and nothing then it's your motherboard/cpu etc..
Aug 12, 2013 | Gateway DX432019 PC Desktop
Motherboard aux power light is flashing
If you mean the power button just flashes green but it does not power on then your motherboard might be the issue. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. In other words just have the power supply and motherboard connected and see if the power light stays solid green. If it does then start re-inserting cards and connecting drives etc (WITH POWER DISCONNECTED) to try and isolate the problem. If not then your motherboard is probably defective and needs to be replaced. Also plug the computer directly into the AC wall outlet.
Nov 16, 2012 | Dell Dimension E521 PC Desktop
PC turns on but shuts down after
shutdown may be caused due to following reason:
overheating
power supply issue
motherboard failure
remove anny external devices if connected to PC...lke graphic cards, wireless cards, external USB or HDD and try
Feb 11, 2012 | HP Computers & Internet
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Installed dlink, says hardware is not found. power light is also off.
If all lights on dlink are off, start by check the power supply. If its connected from the wall to the dlink and still the light are off.
  1. The power supply is bad
  2. The AC from the wall has no current. Check for these.
When you succesfully turn on the dlink, connect the cables as directed. by the manual.
Jul 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Board has a green light but won't turn on
Say properly. There are two green light. One is for motherboard power indicating green light and the other one is for when the PC is started then a green light indicates. Which one you indicating plz explai. Hope then you get the solve
Aug 13, 2008 | ASUS P5PE-VM Motherboard
DWL-122 driver not installing, device not recognized
The wireless adapter will not show on the My Computer. Try to right click the My Computer icon go to properties, then go to Hardware tab then click the device manager button, click the + sign beside the Network Adapters category and check if you have the adapter listed there. If the adapter is listed check if the driver is installed properly by going to the properties of the card.
May 21, 2008 | D-Link Air DWL-122 802.11b Wireless...
Datamax I-4208 Thermal Printer.
I have seen quite a few bad nic cards from Datamax, and that may be the problem.
If you can set the card from the printer, then it is seeing the card as it reads directly to the processor when inserted. But the card can still be bad if you cannot ping from the outside.
Jan 12, 2008 | Datamax M-4208 Thermal Label Printer
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Computers & Internet Logo
Top Thomson Computers & Internet Experts
jimmy Leo
Raj Patel
Wbix
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
