When I print, on the paper there is several blue verticle lines at the top of the paper and halfway down and some of the lines are broken. Thankyou Tom
  • 24 Answers
Reset the Printer If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product. Make sure the product is on, and then disconnect the power cord from the product.
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  3. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  4. Reconnect the power cord to the product.
  5. Press the Power button (When I print, on the - c02062868.gif ) to turn on the product. If you have duplexer try to open it and clean the rollers of the printer and the duplexer. This usually happens if the rollers are dirty.
Posted on Mar 26, 2011
THE PRINTER WILL PRINT BUT WITH MISSING TEXT IN 3 PLACES LIKE VERTICLE LINES RUNNING DOWN THE PAGE
check where the paper enters the print path, there are probably small pieces of paper or other debris that have fallen in and are blocking the printing in those three places. canned air should clear it up if they are not too tightly wedged into the rollers.
Oct 15, 2014 | Panasonic KX-MB781 Laser Fax, Copier,...
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Black stripes down paper
You remove the drum/toner cartridge and run the blue tab on top back and forth several times then blow out the slot with canned air, while it's out you reach inside with a soft cloth and wipe the narrow window above where the drum sits, open the back door and shine a light inside to see if the lines are on the fuser roller, if there you will need a new fuser.
Feb 01, 2010 | Brother HL 5250DN Laser Printer
Just replaced the glass on an HP C4150. When I use the copy feature all it prints is verticle black lines. Must be somethihng with the scan head as otherwise the printer prints okay.
Look for debris on the scan head face--all it takes is one tiny speck to create one line down the paper. Make sure the connector for the head is plugged in securely on both ends.
Nov 17, 2009 | HP Photosmart C4150 All-In-One InkJet...
There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printing incorrectly
You'll find that there's two soleniods behind the power supply and the PWB assembly, you need to replace the top one of the two.
Jun 15, 2008 | Epson AcuLaser C2000 Printer
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
Printer not printing
If this printer has the duplexor feature there is a plate just above the paper tray and the paper may be stuck in there. Pull out the paper tray and look for a sorta blue button on the top right side inside of the printer. Push that button and the duplexor tray will drop down and that is where the paper may be hiding.
Nov 07, 2007 | HP LaserJet 2200D Printer
32 people viewed this question
k24674
jasbo
jasbo
