Question about Acer Computers & Internet
Please help my acer laptop charges only till 85% and next it was 84% it slows down to 1%...please how can i get back the charging to 100% please....
    President:
  • 1,623 Answers
Your battery is dying hence why its not completing the charge, buy a new battery when it dies
Posted on Mar 26, 2011
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Why my acer 4741G battery can't charge until 100% and stuck until 86% charge even I have to wait for 3 hours?it's already 1 year since i buy this laptop. Need more assistance, I hope for next, my...
Typical behavior of a faulty battery, cells are not accepting full charge... If its still under warranty, you can get the battery replaced no charge, otherwise you're in to fork out over 100 USD for a new battery pack.
Aug 20, 2011 | Acer Computers & Internet
My Acer Aspire one dosent charge completely to 100%, it stops at 87%. I have tried letting the battery run down completely, then starting a new charging process. formally it charges to 100%, then 3 days...
Hello.
From your description, your battery is losing its charge and needs to be replaced.
I'm experiencing charging problems with my own system and I noticed that the A/C adapter is very slightly frayed. So, check your A/C adapter as well and be certain that it is charging when you leave your system charging overnight. If you are still experiencing a problem, replace your battery.
Hope this helps.
Apr 02, 2011 | Acer Aspire One PC Notebook
Hi, I bought Acer4741Z from India on September 2010............now, when i charge the laptop, it shows 52% charging and it wont go till 100 %. Any solution for this............pls help..............
When you first bought the laptop did you fully charge the battery for at least 20-24 hours before use? To ensure the lifespan of your laptop battery is long you will need to follow these easy steps:
1) Charge the battery at least 20 hours before use.
2) Completely drain battery power before you charge it again.
3) Try not to have the laptop battery plugged in if you re going to use AC directly from the wall socket.
You may need to purchase a new battery as this one's lifespan seems to have been reduced as it can only hold 52% charge. When you purchase another follow the above steps.
Feb 26, 2011 | Acer Computers & Internet
Acer netbook battery cannot reach 100% charge?
As rechargeable batteries age they build up what is called a 'memory' or a 'charge memory'....
Let me explain how this works...you have a new battery and you run your laptop normally until it hits 15% charge then you charge it up and use it again until about 15% then charge it again....with the charge only dropping to 15% the battery builds up a 'memory' of that over a period of time (usually over at least a year up to a couple years) and then your battery's maximum capacity is no longer 100%. Same thing happens if you dont charge it fully each time, after a while it becomes incapable of taking a full charge.
What you can do to stop that in the future....when you get a new battery every now and then run its charge down to 1% then charge it to maximum. By doing that on a regular basis you help make sure the battery remembers its full charge capacity.
Feb 19, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 11, 2011 | Computers & Internet
My ACER Aspire 3810-TG battrey is not charging (the message on Windows 7 Energy settings screen - 85% available (battery plugged, no charging)
A BIOS update can resolve this issue and allow the battery to charge up to 100% in Windows. The BIOS update can be performed either before or after the symptom appears
You can Get the latest BIOS from
http://gd.panam.acer.com/
Dec 04, 2010 | Acer Computers & Internet
My battery not getting chraged ! Have been using it since July 2010 ! Help please !
1.First,You do one thing update your battery bios(Download from visit www.acer.co.in and then service and suppor and then driver download and then notebook and then your laptop series and then model number and then choose correct opertaing system and with
correct bit(weather it 32 or 64))
2. or 1.first Instal the E-power management to your machine.(Didn't had means kindly download the application from our website www.acer.co.in.
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 23, 2010 | Acer Computers & Internet
My acer aspire 4730z doesn't come on nor charge but charger is working
Nov 22, 2010 | Acer Computers & Internet
Acer aspire 6920 battery problem.. laptop only recognizes the battery and will not charge now... and only lasts a few minutes
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
Nov 16, 2010 | Acer Aspire 6920 Notebook PC
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
