New mobile hard disk targa mobox 320 have attached box to another computer and it will not instal, blue light flashes and it makes a noise. I have saved important documents to the device and need to retrieve them.
SOURCE: Conecting Blue tooth phone to acer laptop
Visit this link to download the bluetooth driver http://support.acer-euro.com/drivers/notebook/as_5630.html
Posted on Jan 06, 2008
xerick
  • 139 Answers
SOURCE: Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
Posted on May 23, 2008
  • 8 Answers
SOURCE: retrieving information from my external hard drive
Check to see if you can see your drive in DOS. To start ...run ...type in CMD and hit return. Then type E: (it should be the last drive letter...if not e: try F: etc..).....and return ...then type DIR and hit return....can you see the files on the drive ? might be security software you have running or it might be one of the Microsoft services not running....try the above 1st it should prove if its a windows problem..
Posted on Mar 30, 2009
bootz84
  • 197 Answers
SOURCE: I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
Posted on May 04, 2009
bob_computer
  • 3153 Answers
SOURCE: usb2.0 hdd external hard disk-unrecognizable device
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 08, 2009
My hard drive is coming on but the computer is not recognizing it
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 17, 2012 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Wd3200 aajs external drive light flashes and won't come on.
Get a new case and transfer the hard drive to the new case. You can get cases at any store that sells computer parts and several places online.
https://www.walmart.com/c/kp/external-hard-drive-enclosures
Sep 25, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
When i boot into the operating system which is win7 machine freezes and shows up a blue screen.when i placed the hard disk into a usb external case and connected it to a pc a message box showed saying i...
Get a windows 7 install or repair disc. Make sure your pc boots from the disc drive. When you get to the installation screen tick REPAIR YOUR COMPUTER. Then select the installation you want to repair and choose STARTUP REPAIR.
Mar 13, 2011 | Fujitsu (MJA2320BH) 320 GB SATA 3 Hard...
Screen is black. Blue light flashes intermittently. Makes clicking sound when it flashes. Rebooting computer doesn't help. Unplugging and re-plugging in monitor doesn't help. Disconnecting and...
is the monitor making the clicking noise or your computer
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 17, 2011 | ViewSonic VX1935wm LCD Monitor
We understand that your problem is: hello i was using my buffalo ministation 320 gb external hard drive about a week ago, it was working fine but I left it on my bed when I was done. About 2 days later I...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Buffalo Technology 320GB Ministation...
My External Hard Drive isn't working anymore, to say the just of it. It's on, lights on(not flashing, it flashes when it's being written to or accessed), usually has a regular clicking noise from it...
When a hard drive makes a clicking noise, this indicates the hard drive has failed and if the BIOS and the Computer Management does not detect it, then this confirm a hard disk failure.
To get the computer operating again, replace the hard disk, then install Windows on the hard disk using the Windows installation CD and the Windows product installation code that is on the label on the computer then install the device drivers and your programs.
Oct 21, 2010 | Samsung Computers & Internet
Iomega 320 portable drive connection problem
sounds like a defective drive. maybe it took a bump in shipping?
take it back right away.
Sep 10, 2009 | Iomega (33576) 320 GB USB 2.0 Hard Drive
WD ITB harddrive makes noise
From what you've described, it sounds like you have an external drive, rather than an internal. A clicking noise generally emplies hard drive failure, but sometimes the problem could be the actual USB cable. Have that switched and if the problem persists, try running WD's diagnostic software for any fatality. This will only work if the drive is visible in disk management (not necessarily my computer).
Apr 09, 2009 | Western Digital (WD3200JS) 320 GB Hard...
TARGA TRAVELLER 1591 TRYING TO DUAL BOOT ITS GOT VISTA I WANT TO INSTALL XP PRO BUT XP CANNOT SEE THE HD IT NEEDS THE DRIVERS. HOW DO I INSTALL THE DRIVERS FOR A SATA DRIVE INTO MY XP INSTALLATION CD
OK I managed to install XP on Targa Traveller on 1591!
With the CD of window XP it is necessary to make F6 for the starting up of the installation and to use a diskette with the pilots(drivers) SATA of NVidia nforce. Naturally the most practical are of incorporated the pilots(drivers) SATA into the CD Windows but I knew how to make;) link for the pilots(drivers) SATA:
Http://garlon.free.fr/Appli/NVidia /
If after the intallation of the pilots(drivers) at the beginning of the copies of file An error of copy of file (cann' t copy spin NVr dll) make Esc (65 files nvidia not copied) and continue the installation up to the restart.
I put out(switched off) the computer, removed the hard disk to put it in an external box usb on another computer I have to copy files dll to System32 or system32 / drivers, file .inf on file windows/inf and file .sys on system 32 or system32 / drivers
I restarted the computer and finished the installation links Pilots(Drivers) xp (I am not sure for Chipset drivers Chipset...you must verify)
http://fred.garlon.free.fr/Appli/Targa
Good luck
Sep 26, 2008 | NEC PowerMate VL3 (ND361799406) PC Desktop
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
