Question about Husqvarna Designer I
Husqvarna Viking Designer 1 problems using metallic thread
I have the original Designer 1 (not USB) sewing machine. I just spent 6 hours on a very simple design using metallic thread (YLI brand). I broke 15 needles and countless problems from the bobbin not working properly to thread breaking. I finally got the design done but I threw away all of the metallic thread I own. What causes this to happen and has it happened to anyone else?
  • 201 Answers
DON'T put lubricant on the side of your thread spool!!! The computerized machines' tensions are so finely tuned, the lubricant can completely flumox your tension sensors. But then again, you had so much trouble anyway, guess it can't be any worse. However, it might leave traces of lubricant in the tension discs and cause you grief when you are using ordinary sewing or embroidery thread.
I am always wary of using metallic thread on my Des.1 - some machines seem to like it, others don't. Mine is a bit in between - sometimes I have no trouble, other times it plays up merry hell. It has been suggested that the metallic thread should be kept "moist" and some people keep theirs in the refrigerator for an hour or two before using it. I have never tried this, so cannot speak as to its efficiency.
Making sure the thread reels off smoothly is the best tip, along with slowing down the machine and using Metallic or at least a Topstitch needle. Different threads are wound onto the spools differently so you will have to examine the spool and decide how it will unwind with the least bother i.e. upright or on the horizontal spool. Others report success with placing the spool upright in a cup or glass (to stop it falling over) and feeding the thread up through a thread stand.
Then there are those that say the longer thread path you can get the better to allow the thread to lose its kinks before reaching the tension discs. I never had success with this - seemed to me it just made a longer thread path to create more kinks!
You can buy embroidery designs which have been digitized especially for metallic threads, so maybe that might be an option for you. Designs with lots of small, tight stitches close together or on top of each other are NOT suitable for metallic thread. You could try upsizing your design by one click in both directions (width and height) to make sure the stitches are spaced out a bit. This should not affect the integrity of the design noticeably.
Watch the thread as it is spooling off the reel, not the needle, when you sew out a design and have your finger on the Stop button, ready. That way if the thread is not spooling off smoothly or catches, you can stop before disaster strikes.
Hope some of the above is useful to you.
Posted on Oct 19, 2008
I found with metalic thread the spool has to be in the upright position when embroidering or all sorts of problems occur.
Posted on Oct 10, 2008
    Novelist:
  • 192 Answers
Metallic needles have a larger eye and lumpy thread passes through easier. Slow your machine down to its slowest setting while using metallic thread. Always use a metallic thread that is fairly smooth to the touch. If it's not feeding through your tension assembly very well, apply a line of TriFlow lubricant down the side of the thread on the spool so that every wrap that comes off the spool has just a little lubricant on it.
Needles breaking probably means that the thread is dragging in the eye. Everything that I listed above will help.
Posted on Aug 08, 2008
Try using a bigger needle
Posted on Aug 06, 2008
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
I recently purchased a Husqvarna Viking Designer SE online and just unpacked it obvously from the original factory packing. The machine turns on, lights come on, motor runs and the machine even sews...but,...
Sorry. Sounds like a dead LCD screen. It will have to be replaced by an authorized Husqvarna Viking dealer. Be sure it is an authorized dealer. Check the Husqvarna Viking website for dealers close to you. Http://www.husqvarnaviking.com/us
Nov 16, 2008 | Husqvarna Viking 1
Husqvarna Viking Designer 1 Beeper
You can't. Believe it or not, it is supposed to be helpful! I know it is annoying though. I have owned my Husky for 10 years and it isn't something you can get rid of.
Nov 17, 2007 | Husqvarna Designer I
Sewing Machines Logo
322 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
