Question about Garden
My FH580v Kawasaki Engine is surging and dose not idle.
2 Suggested Answers
Dustybobcat
  • 39 Answers
SOURCE: idle hunting
I feel that with the description you have given, that the problem lies with your carby.
It's either
- the choke is coming on
- the carby needs a service. Either a shaft is sticking or the fuel jets are blocked.
- low engine oil
these could all cause the above problem
Posted on Apr 05, 2010
Free engine diagrams
http://www.bridenbeckers.com/pages/oemparts?aribrand=ARN#%2fKawasaki_Engine%2fFH580V-ES20_4_Stroke_Engine_FH580V%2fCYLINDER%2f%2fCRANKCASE%2fFH580V-ES20%2f99907-61680011
Jul 22, 2014 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
What is causing my kawsaki 580v to smoke
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
May 16, 2014 | Kawasaki Engines NEW 19 HP KAWASAKI ENGINE...
Kawasaki fh580v
Possible the needle and seat are not closing properly anymore in your carburator .
Dec 15, 2017 | Sport & Outdoor - Others
Fh580v has weak spark
Weak battery? That is the simplest and best way to eliminate that factor. Even if it runs it can seem charged but will be giving less power to some components. Maybe the charge system is weak. Run it with jumpers or a diff battery and check spark. Same thing? Ok. Check all your grounds, connectors, wiring, and particularily the coil terminals for corrosion and looseness. All good? Test the mhttp://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CE4QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DAsRoSeyJ38o&ei=sNB-Uq2uIOzMsQSQoIHoCg&usg=AFQjCNEG8eK98F5T6nGjXuI3OVJYYDfp8Q&sig2=YHYXfQdNQXfu8bHmlEOv3Q&bvm=bv.56146854,d.cWcagneto and ignition coil. Heres a video. Only other thing could be bad plugs or wires. Good luck.
Nov 08, 2013 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Remove clutch from kawasaki fh580v
to remove clultch pulley remove crank bolt unplug pulley first then ie should pull off some times you mights need to need to use a pulley remover
Oct 26, 2013 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Can I replace the kawasaki 19hp FH580V AS14 with a 20hp FR600V AS05R on a Phazer lawn mower
Hello friend... I know people that have had replaced their Kawasaki FH580V-AS14 with the FR600V-AS05R... so, the answer is YES, SURE YOU CAN !!
Mar 11, 2013 | Garden
2008 Kawasaki Ninja 250R idle surging
Hi, Ragh and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
engine surge ninjette org
Hard idle surges
Kawasaki Ninja 250R Service Manual
OEM Parts for Kawasaki
2008 Kawasaki NINJA 250R Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 22, 2017 | 2008 kawasaki Ninja 250R
The governor on my fh580v kawasaki engine doesn't seem to be working. After I start it up it slowly speeds up to a high rpm. If I run the governor arm with my hand it works fine but doesn't have...
Your throttle plate and or governor arm may be out of whack. Download a technical service manual in a pdf off the internet and follow the instructions on how to set them. Be sure to put a 6mm pin or bolt in the hole while adjusting. You want to set your governor arm prior to setting the throttle plate. I had the exact same issue on mine and that was the resolution. Good luck and be sure to set your rpms correctly for high and low speed idle. Again the technical service manual will provide info on how to do it all. They sell a little hour / rpm gauge on ebay or amazon for like 15 dollars where you just have to wrap the wire around the plug wire 4 to 5 times and it will read your rpms. :)
Feb 26, 2012 | kawasaki Garden
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
