Question about Emerson EWL20D6 Television
Emerson model EWL 20S5 c
When i turn my tv on it will only stay on for about 3 seconds, it was working fine the day before. i have not moved it, there has been no stroms to harm it, and no apparent reson for it not working. I call Emerson they said it was no longer under warranity, but i could ship it to them at my own expense and they would try to have it repaired and returned in 4 weeks. Do you have any other suggestions? Does Sears repair Emerson products? We have had this tv less than 6 months, and it dosent seem fair to have to pay repair on it so soon.
  • wingster09 Mar 30, 2009
    I too have a unit the shuts itself off without warning or reason (same model as reported). ...seems to happen with the tv has been on for a while. Once the problem begins it won't stay on longer than a couple of seconds. Emerson service only said that I would need to take it somewhere and have it repaired.
  • 16 Answers
This can be fixed by replacing one of the inverter transformers
Posted on Oct 09, 2008
6ya staff
SOURCE:
Where can i get a manual to help me program a LCD EMERSON TV model EWL 20S5 TVwill not show picture if not connected to cable
<a href="http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html">http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 25, 2010 | Emerson EWL2005 20 in. LCD Television
My LCD TV EW 20S5 C shots off after 15 seconds,
one of the ballist transfomers is failing on the inverter board your should have a tech replace the bad one easy to find the bad one by a process of elimination
unplug all but one lamp turn the unit on and watch for the lamp to light for a second if it does go to the next by pluging it in may sure you umplug the one you already tested go through one at a time
Nov 28, 2009 | Emerson EWL20D6 Television
Tv shuts off after 6-8 seconds
capacitors in the power supply, they all should be replaced, before it takes out the rest of the ps. there are companies that rebuild them if your tech is not up on repairing them.
Jul 23, 2009 | Emerson EWL20D6 Television
I know TV model # but not remote model #
go to remotes.com and enter in your model number.
Mar 23, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Oct 02, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson lcd 20s5 TV
I work for a repair company fixing emerson and many other sets. the fix to your problem is one of the inverter transformers, there are 6 in the 32". once it has been replaced the set will work great.
Jul 01, 2008 | Emerson EWL20D6 Television
TV with not power up
If it worked prior to moving and not when delilvered, I would take the back off and look for either physical damage or a loose plug.
Jun 29, 2008 | Emerson EWL20D6 Television
EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Feb 07, 2008 | Emerson EWL3706 37 in. LCD Television
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson EWL20D6 Television Logo
160 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
