Question about Dymo Office Equipment & Supplies
I have a dymo label point 150. when you press some of the keys the motor starts moving the label. can i reset machine? I have tried changing the settings but this still does work
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Did you ever find an answer for this issue? I have the same problem
Posted on Mar 21, 2016
SOURCE: Printing
thanks for your solution. just did as you suggested 'artu' and found a piece of tape inside. works a treat now.
Posted on Dec 13, 2007
  • 7 Answers
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
Posted on Dec 31, 2008
SOURCE: dymo label point 200
Dymo website, Support Tab:
http://global.dymo.com/enUS/TechSupport/default.html
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
SOURCE: Dymo Labelwriter - Compatible Labels
printer says its out of paper after replacing it I still get the same message
Posted on Oct 05, 2009
How to print numbers
A manual for such a machine (you don't have a specific model) can be found here (
http://download.dymo.com/dymo/user-guides/LetraTag/LT100H/UG/LT100H_UserGuide_en-US.pdf ) There is a Num Lock key (a padlock outline and '1 2 3' ) on the key. There are keys that have auxiliary numbers beside them. Toggle on the num lock key and then try pressing the key with the number beside it. Should work now :-)
Good Luck!
Nov 11, 2015 | Dymo LetraTAG Thermal Label Printer
How do I make the font larger on Dymo labelmanager 150
Changing the Font
Six font are available for your labels:
Arial Narrow, Arial Normal, Arial Wide, Times
New Roman, One Stroke and Frankfurter.
When you specify a font size, that size applies
to all characters on current page.
To set the font
1. Press the Font key.
2. Use the arrow keys to move to the desired
font and then press OK.
Also here the link to the manual for further instructions.
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
Apr 30, 2012 | Dymo Office Equipment & Supplies
How do I change the font size on a Dymo LabelManager 350?
Please follow this instructions
Changing the Font
To set the font
regards
Mar 25, 2011 | Dymo LabelMANAGER 350 Thermal Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
The Dymo tape editor screen will not let me enter text
  1. Ensure software and drivers are compatible with your OS.
  2. Re-install the drivers and software again.
Nov 15, 2009 | Esselte Dymo LabelWriter DUO for creating...
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
768 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
GuruGrundy
GuruGrundy
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
