Question about Ertl 150 John Deere Excavator
The track on the track hoe keeps falling off. Is there a way to repair this or purchase a new one. We have repeatedly clicked them back together and the metal seems to be worn and not staying together. It seemed to be defective from the package.
Pel job 250 track removal procedure
First step is to remove any tension in the track by loosening off any adjuster rollers or springs.
the normal method to remove tracks on a machine is to remove a pin about the middle of a front sprocket in the track and then back the machine along the track until the undone part falls to the ground
jack the machine off the track and work on the sprocket. Replacement is to tie the end of the track back onto the drive sprocket and drive forward until the track is on top of the sprocket. undo the tie and retie it to the front sprocket and continue to slowly drive forward. eventually the ends of the track will be almost together. One end will be on the ground and the other end will be just above it . Use some method of holding the two ends together so that the pin can be reinserted.
If it is a small machine and runner tracks you may be able to undo a pin in the middle at that top and just lay the ends back wards and forwards. fix the sprocket and then pick the ends up and rejoin.
Feb 20, 2015 | Cars & Trucks
CD player clicks while playing some CD's
Sounds like it's worn out, best take into the shop for repair, should only cost $20 with parts.
Dec 25, 2017 | Pioneer PD-M426 6-Disc CD Changer
Have a porter cable 3x21 belt sander and the sand paper keep rolling off the wheels
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
Aug 26, 2011 | Porter Cable Garden
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
Window wont roll up or stay up...keeps falling down
your window track sometimes called a transmission needs to be repaired or replaced. door panal needs to be removed than you can see the problem. new window transmissions can usually be found on the internet.
Nov 21, 2010 | 1994 Oldsmobile Cutlass Supreme
1990 Passenger window keeps falling off tracks. Had new window replaced because it shattered, but still doesnt roll down right. What is wrong?
Your window has a lower glider that floats on a track, and sometimes when people replace the glass they fail to replace the stopper on the end, which acts as a brake. If you can see the track with the panel off, watch as you roll up the window and see if the rollers stay in the track. Also remember that the glass has a glider glued to its back side to keep the window level as you roll. The most common problem here is the glass slipping off track, and a new track inserted into your window frame will fix that (Dealer Item)
Mar 10, 2010 | Buick Regal Cars & Trucks
My Apple Ipod Touch (8G) keeps repeating the same song. How do I shut off the repeat feature? I can't even find the repeat feature. Thank you.
On the track click on the screen at the top left under the timelinethere is a symbol of two arrows in a circle by touching the symbol you change whether a track is repeated or not
Oct 21, 2009 | Apple iPod touch
Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Mar 01, 2009 | Gladiator Gear Track Pack
Ertl 150 John Deere Excavator Logo
63 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
