Question about Apple iPod nano 2nd Generation MP3 Player
Cannot play 2 song on my ipod
Hi
I've bought 3 songs last night from the itune store and then transferred them to my ipod. Only one of the songs will play the other two have an exclamation mark next to them and will not play from the ipod or from my ipod folder through the pc.However they will play from my itune music library. What can I do to fix this?
thanks
Leanne
If you have a PC, go to My Music, open the iTunes folder and open iTunes Music. If the files of the music you purchased are present and the songs are in the file, double-click on them and they should recover on your iTunes. If not, you need to report a problem to the iTunes store. Hope this helps!
Posted on Feb 12, 2009
  • 2,071 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Hopes it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 13, 2008
UNABLE TO GET MUSIC FROM MY IPOD TO MY COMPUTER
If you purchased all of the songs through itunes store, please follow these steps:
1. Open up Itunes and Click on Itunes Store
2. Once you're in the Itunes Store look to right side of the screen and you should see the word "purchased". Click purchased and you'll be sent to a purchase screen.
3. Click on "All Songs" and then it will show all the songs you've downloaded. From there you just hit the button that looks like a cloud with an arrow on it, and it will download all the songs all over again.
If you didn't purchase them through Itunes, then you'll have to download software that will strip the songs from your iPod onto your computer. And here is a step by step guide show you how to do that, hope it helps.
http://www.ipod-transfer-copy.com/how-to-transfer-music-from-ipod-to-computer-itunes.html
Aug 22, 2013 | Audio Players & Recorders
Tip
How do I Sync Songs onto my iPod
<p>Your iPod can function as a jukebox all in the road, with the numbers stored in that you select and manage. To control what the numbers are stored on your iPod, use iTunes software to transfer music to the device. This transfer process is called "sync" your iPod with your computer. If your iPod is synced with iTunes, you can automatically tracks from your music library, or add them manually, depending on the options to enable synchronization. <br /> <p><br /> <p>How can I sync songs automatically? <br /> <p>1. Connect your iPod to your computer. <br /> <p><br /> <p>2. Open iTunes if it does not start automatically. <br /> <p><br /> <p>3. Click your iPod in the iTunes main window. <br /> <p><br /> <p>4. Click the "Music" tab. <br /> <p><br /> <p>5. Check the box next to "Sync Music." <br /> <p><br /> <p>6. Click "Entire Music Library" for all the songs loaded into your iTunes music library on your device to synchronize. <br /> <p><br /> <p>7. Click on "Selected playlists, artists, albums and genres" for some of the music content to sync with your device. Check the boxes for each song or album you want to synchronize the lists that appear when you click this option. <br /> <p><br /> <p>8. Click "Apply" to sync music with iPod. <br /> <p><br /> <p>Syncing manually Songs <br /> <p>1. Click your iPod in the main iTunes window, click the "Summary" tab. <br /> <p><br /> <p>2. Check the box next to "Manually manage music and videos" and click Apply. <br /> <p><br /> <p>3. Click the "Music" option in the "Library" heading on the left side of the screen of iTunes. <br /> <p><br /> <p>4. Drag any number you want to sync to the iPod icon. <br />
on Aug 05, 2011 | Computers & Internet
How do i trasfer music from windows music player to ipod?
Hi john long3...
These instructions are for Ipod's only...no other MP3 player.
You can transfer songs to your Ipod using ITunes (Apple ACC format) downloaded and installed with the songs you want.
1...You need to install Itunes on your computer,
a...Turn on Windows Media player,then transfer your music from Windows media player to ITunes
2...Download all the songs you want on your Ipod to ITunes on your computer.
3...Plug your Ipod into the computer with ITunes running.
4...ITunes will recognize the Ipod and open it.
5...Highlight the songs you want to download to your Ipod.
Please take time to rate me
Sep 09, 2011 | Audio Players & Recorders
I cant download to my ipod i cant get sync in itunes..how do i download songs to my ipod
You just need to import your songs into iTunes library, then make a playlist with the songs, connect your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod.
If iTunes not works for you, You may try this ipod transfer, it's a nice iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes.
Apr 10, 2011 | Apple iPhone Smartphone
How to transfer songs from pc to ipod
Hi.
You may transfer the Songs from the Computer to the iPod Device by using the iTunes Application.
However, please feel free to contact for further information about the Application and the detailed steps to transfer the Songs.
Oct 31, 2010 | Acer Aspire4720 14.1-inch Notebook PC PC...
When I plug my ipod into my computer, it doesn't show up anywhere. Neither in "My Computer" or itunes. I'm running Windows XP Professional. I've tried resetting and forcing it to disk mode, reinstalling...
Maybe you should try this third ipod manager tool - Daniusoft iPod transfer:
Key-features:
1. Sync videos/songs from computer to iPod without iTunes ;
2. Backup videos/songs off iPod to computer smoothly ;
3. Transfer iPod video/music to iTunes .
I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well.
Dec 30, 2009 | Apple iPod nano
Hi my apple ipod shuffle 1g wont charge.. or play songs
You are supposed to transfer songs usin itunes....simple drag and drop doesnt work.... You can download itunes from www.apple.com\itunes
If you are already using itunes,perform a restore on the ipod using itunes...you will find restore option under the summary tab in itunes.
Sep 29, 2009 | Apple iPod shuffle MP3 Player
I have an ipod nano 8gb, i'm trying to put my songs i have already saved to my computer onto it, but can't seem to do it do you have any advice ? Thanks Oz
This ipod manage software can transfer the files from ipod to computer,computer to ipod,ipod to iTunes,ipod to iTunes, and iPod to iPod:
please click here for more details.
Hope this Helped!
Sep 06, 2009 | Apple iPod nano
Transfer music from one ipod to another
I recommend you am iPod to iPod/Computer/iTunes Transfer which can transfer your iPod and iPhone music, video, playlist, photos back to computer and iTunes.
If you own more than one iPods, AVCWare iPod to iPod/Computer/iTunes Transfer can simultaneously manage all the iPods in the same interface, you may transfer files among these iPods by drag-and-drop.
Hope it helps!
Apr 12, 2009 | Apple iPod MA446LL/A MP3 Player
Basic Transfer of Songs on my computer to White 4GB MP3
http://www.askdavetaylor.com/how_do_i_put_music_on_my_apple_ipod.html
Dec 01, 2007 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
129 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
