Question about Husqvarna Chainsaw Piston Kit for 61 Chain Saw
I have a husquvarna 61 that just started making a noise like a squeek in the clutch area. I took the clutch off and cleaned the area and it worked fine for awhile but started up again. any ideas? thanks
  • Husqvarna Master
  • 2,239 Answers
It may well be the drum bearing, if this is dry it will sqeek, you can grease this bearing through the end of the crank without removing the clutch, this bearing rotates on the crank if the saw is idling, it is not good to leave the machine idling for any lenght of time,it is always better to switch the machine off whilst moving logs ready for cutting, there is no sealing on the bearing so the grease is quickly lost, when the saw is cuttin the bearing is not in use as the drum rotates with the crank.
Posted on Mar 26, 2011
Took the carburetor off cleaned it the bike started then died. After the every time you try to start the bike it make a screetching noise and won't start. It's a 2011 klx 140.
the starter motor is probly toast or the gears connected to it--u need to inspect area w a service manual-can findum online ir library--or bring it to a private mechanic not a dealer------------try push starting by puttin it in 3rd gear w clutch in-then run w bike and pop clutch-caution wear a helmet and footwear
Jul 07, 2014 | Motorcycles
Accelerator squeeking and internal crunching
Acc. squeek noise due to linkage issue, get it lubicated.
Regarding the clutch, you check the links, clutch plate springs condition. If there is wornout parts get it replaced. Gear shifting will be solved once you fix your clutch problems.
Jun 04, 2010 | 1998 Hyundai Elantra
My Husquvarna Model 61 coils are not working I need a new coil where will i get an old chainsaw for spare parts for my machine now? I am in Sydney, Australia
check and search on E Bay mate, search for "Chainsawa' and "husquvarna", you should be able to pick up something cheap, also the coil from other Husquvarna models may fit, example, a 36 model coil, may fit a 61. A new coil is available from any mower and chainsaw shop, cost about $80.
May 31, 2010 | Husqvarna Chain Saw 20" Bar
Car makes a squeeking noise when driving then it killed on me today when the squeeking was very loud.
check for a siezed pully under the hood remove the belt and check to see all pullys spin free with no noise also check the AC clutch make sure it free spins.
Dec 02, 2009 | 2002 Ford Mustang
2004 Saturn Vue V6 Honda motor
ld still be the ball joints. yhe sound travels. place your hand on the ball joint and have someone bounce the car you can almost always fill the noise when you hear it.
Jun 11, 2009 | 2004 Saturn VUE
MY CLUTCH STARTED SQUEEKING WHEN PRESSED
The squeaking would have either been caused by the clutch release bearing or the pilot bearing in the crankshaft if it has one (pilot bearing). It doesn't really matter as the transmission has to come of to repair either of these. It is hard to tell what you were describing, but whatever you do, don't spray any more WD 40 at anything! It will ruin your clutch and clutch fluid if it comes in contact with either. If the clutch fluid reservoir gets low, only use new brake fluid to top it up.
Mar 11, 2009 | Hyundai Motor 1998 Accent
Squeeking noise when i start the engine, with the engine cold
Probably serpentine belt to loose.
It is common. Have it checked.
Also can be water or oil getting on belt and it starts slippering and makes the noise.
Good Luck
Dec 12, 2008 | 2007 Volkswagen EOS Convertible
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Husqvarna Chainsaw Piston Kit for  61 Chain Saw Logo
134 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
