Question about Maytag Washing Machines
I have a Maytag front load washer which I can't seem to level. It is on uneven floor, we used the floor leveling legs, but where should we place the level on the top? On the side, which is raised: or in the middle, which is lower than the sides? We get different results on both and have tried 2 different levels. Also, the floor it is on is hardwood flooring about 75 years old and would like to put some kind of cushioning to absorb some of the vibration. What would you suggest? Thank you for your expertise. We don't really know who to ask, I hope you have the answer.
  • 2,510 Answers
You can check the level on the top, across and fore and aft and both must be level. It is actually more important that the machine is standing firmly on all four its feet, you should not be able to rock the machine by hand, and this creates a problem with your if it is not solid. Any vibration on a sprung floor will be amplified and any unbalance in the machine will cause ot to bounce on the floor. Rather than try cushion the vibration, try spread it across the area of the machine by placing a piece of some hard plate under the machine that all four feet stand on and you can place a piece of thin hard carpet under the plate to protect the floor. It will need to be water resistant, so some plastic sheeting about 3/8" to 1/2" should work for that.
Posted on Mar 26, 2011
I have a Maytag Model # LA806-02, which dances across the flor when in the spin mode. Tighting the three centering spring has helped very little.
If your Maytag is dancing across the floor the most common problem is the leveling. If one or more of the feet are not level it ill wobble and walk around the floor. When you level the machine on the top both directions make sure the set nut is tightened so you will not have to retighten it again later.
May 08, 2011 | Maytag Washing Machines
My matag washin machine worked perfectly on a cement floor we moved it into a tile floor and it shakes all over the place it tried to level it but it still shakes
You can adjust at least two of the legs o the washer. Lengthen the leg till all four are securely on the floor. It should be easy to adjust with the washer tilted on two legs. It's not uncommon to need to adjust the legs from one floor to another.
Nov 01, 2010 | Maytag Legacy Series Top Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag walking
Hello. I have a few ideas for you.
1. Tilt the machine forward so the back feet are 3 to 4 inches (7.5 to 10 cm) off the ground, then set it back down. The back feet usually are self-leveling--just raising and lowering the machine like this will cause the feet to re-level themselves.
2. Place your level perpendicular to the front of the machine and check to see if the washer is level in this direction. If it is off, readjust each front foot by the same number of turns until you reach level.
3. Go to the carpet store and buy a remnamt which is the size of the washing machine lengthxwidth. Place this under the machine with the four legs all resting on the carpet.
Regards, Joe
PS please rate my answer. thank you.
Dec 20, 2009 | Maytag MAT13MN Top Load Washer
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the...
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Sep 24, 2009 | Kenmore Elite 45986 Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Leveling Maytag Neptune
Leveling a washer can be a pain sometimes.
1. You must have a solid foundation. The floor where it sets must be good.
2. Use a level. When adjusting the legs keep the washer as close to the floor as possible.
3. Problem inside the washer. Look inside for anything obvious i.e. loose springs, loose counter weight.
Dec 21, 2008 | Maytag Neptune MAH6700A Front Load Washer
Leveling ge washer
Try using plastic shims from any Major hardware outlet, and place on the right side until even. Make sure the shims, or even a block of wood the space you need to level the unit. Try screwing the back right leg out as far as you can and screw the left back leg in to shorten it, if you have that feature.
Nov 15, 2008 | GE WSM2420T Top Load Stacked Washer /...
Good afternoon, I recently purchases a Maytag Washer & Dryer, 100th Anniversary Model. As this was my first major purchase in 18 years for a new set I was looking forward to getting the pair home and...
Hello..
If your washer has four adjusatable leveling feet then one method would be to tilt the washer to gain access to the back feet first ( since they are the hardest to get to once the washer is positioned into its final location ) and spin them down so that they are projecting out ~ 3/4 inch from the cabinet frame. Then position the washer back into its final location in your laundry area. Check the side to side level of it by placing a spirit level ( normal carpenters level) across two flat surfaces of the washer cabinet on top and near the back) If they need a slight adjustment, then do that now.. re-check the side to side level until that is OK. Once you have the back part of the washer leveled side to side in the back and while it is in the final location of your laundry roomm check the front to back level. Use one adjustment leg on the front to get the front to back level on that side, then adjust the other front side leg so that it too is making contact with the floor and your front to back and side to side are all level. That is one way of setting it up however if after you are confident that it has been leveled this way ( all four feet are contactint the floor and that side to side and front to back are all level) and it still vibrates violently, you may have another problem with your washer that will need to be addressed. It should still be under warranty and I would speak with the sales people or their service department to set up an appointment to get it resolved. That is ONLY after you feel confident that the washer is level in its user position. Hope this helps you...
Oct 05, 2008 | Maytag Washing Machines
Washing Machines Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
