Question about Life Science Kilotech Scales Klb-600r Measurements Weights
Lost manual to Weigh of Life nutritional scale
I can't stand my scale ! Brand new about 3 weeks now and this scale everyday will give me a different weight. Need help
Hello Diana Pereira,
It is not totally beyond comprehension... that it is defective
(you might merely return it... (just my opinion)).
A few rules... weigh in same time...
(soon after sleeping is best (pre-eating/drinking))...
same clothes... (worrying does no good)...
Floor should be even (& same spot).
A single extra dose of salt is typically reflected in
added water weight... the next morning.
Digital scales are particularly annoying... Especially
if you think CONSTANT WEIGHT checking will
aid GOOD DIETARY habits in any way...
Only vigilant CALORIC intake and good nutrition
will work on that...
Take that scale back & get one that works...
Carnac the Magnificent
Jul 14, 2017 | Health & Beauty
I need a free user manual for a chefmate digital scale. Where could I find one?
https://www.tradebit.com/filedetail.php/140213290-chefmate-digital-nutritional-scale-user-manual-food
Dec 31, 2014 | Health & Beauty
Spring scale can be used to weigh it?
Spring scale shouldn't to weigh heavy items, it may easily malfunction. But it can be weigh some small items.
Dec 30, 2012 | Health & Beauty
Need manual for weigh of life scale
I have the instruction manual for the Weigh of Life scale. I can mail you a copy for only $5 (PayPal), as I have to go get copies made.
spspirk@gmail.com
Mar 26, 2011 | Digi Health & Beauty
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Instruction manual
I would at this point return to the place that you bought the scale or some place that sells the same one you have and buy it and then photo copy manual. Then take your reciept and the scale and go get your money bac! Good luck.
Nov 21, 2009 | Health & Beauty
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Need manual for the Chefmate Digital Nutritional Scale
Redtruckie,
The contact information from my manual is:
e-mail: sales@alldmd.com
Phone: 314-453-1606
Customer support: www.weighoflifescale.com
Hope this helps.
Bill
Mar 17, 2009 | Health & Beauty
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Life Science Kilotech Scales Klb-600r Measurements Weights Logo
193 people viewed this question
Top Life Science Health & Beauty Experts
Tom Chichester
schwaa44
schwaa44
Are you a Life Science Health and Beauty Expert? Answer questions, earn points and help others
