Question about Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White
Model #18TFA00, water collecting and pooling under crisper drawers
2 Suggested Answers
  • 2699 Answers
SOURCE: model# 18TFA00 water collecting and freezing
your model number didn't come up,you have to get it off of the machine,if it's a top mount freezer on top it sounds like the drain is blocked in the freezer.you can look for a tech sheet usually attached to the bottom kick plate,pop off the kick plate and the tech sheet should be tucked in the kick plate,it will tell you how to put the machine into defrost,if not unplug the machine,take everythiing out of the freezer,remove the back inside panel of the freezer and with a hair dryer melt out all the ice,you'll see the evap coil on the back wall,under it there will be a drain hole that is blocked,i use a steamer to clear out the line,this is the best way to clear the line,if you don't have a steamer you can try a turkey baster or anything that will blow through the line to clear it,melt out any ice around the hole and then stick a screw driver in the hole and heat the blade with the hair dryer and the blade will melt the ice,the lines are made of plastic so don't heat the blade with anything but the heat of the hair dryer,then try the turkey baster to blow through the line,when you think it's clear pour hot water down the hole,if it drains then you cleared it,if it doesn't keep hitting it with the hair dryer,you can open the fridge door and in the middle of the cieling and against the back wall you can heat that up with the hair dryer,the drain water travels through there to the bottom of the fridge,keep hitting it until the water drains through the line,it might be a good idea to buy a steamer, it's around 50 dollars.you can use it for alot of other things,i use it to clean my harley and the crome and tires of my car,just stick it in the drain hole,hit it with a few blasts and it will clear the line,you can buy a heater for the drain or make one with the ground wire from a piece of house wire or a cable wire,strip off the casing until you get to the copper part of the wire,cut like a 6 inch piece,stick it into the hole and rap the other end around the heater,when the heater comes on to melt off the ice off of the coil the copper wire will heat up stopping the water from freezing in the drain so it won't block up again.let me knoow hoow you make out,good luck.
Posted on Mar 26, 2011
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Ken more refrigerator has no ice maker but water is pooling under the crisper drawers. Model c21tfa95
Check the drain channel at the rear of the fridge just above the crisper drawers and blow through the drain hole with a drinking straw to clear it.
Jul 02, 2012 | Refrigerators
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water is pooling on the top shelf and under the crisper drawers
ur drain is clogged. remove freezer panel and unclog hole where water collects
Feb 12, 2010 | Kenmore Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old...
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Jun 21, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
