Question about Ovens
Hi I have a problem with my fagor 2h-1261 oven. It keeps flashing 0.00 and AUTO but not heating up.
5 Suggested Answers
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
barkencoa
  • 3463 Answers
SOURCE: oven not heating flashing auto
You need to reset the timer to manual from auto to get it to work properly.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
  • 24 Answers
SOURCE: My Blanco oven will not
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
Posted on May 29, 2011
SOURCE: I have a Stoves 900G (White) built in oven, on
where can I get an manual for my stoves 900G combi oven
Posted on Jun 13, 2011
Where to find replacement elements. have found several sites in u.k. but are voltages compatible with u.s. versions?
Hi firstly, U.K uses 110 Vdc and rest of the world or most of the other parts of the world use 220-230 Vdc, so unless your Fagor 5HA200LX Oven has a built in voltage converter from 110 Vdc to 220 Vdc, which most new appliances have these days.
Try these shops:
http://www.fagoramerica.com/shop2/replacement_parts/halogen_oven#
http://www.guaranteedparts.com/category/FAGOR.html
Apr 29, 2014 | Fagor 5HA200LX Oven
Setting clock on fagor 6h-230 x
Fagor appear to be a poor quality brand of oven. I also cannot get the timer to turn on the oven. I am going to find out how to bypass it as I dont want to wasre more money on such bad quality machinery. T P Kennedy
Mar 30, 2014 | Fagor Ovens
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
Oven not heating flashing auto
Thanks.
Nov 11, 2009 | Ovens
I have a Fagor oven 2H1261 model electric short circuit
try checking oven switch could be shorting or usless
Sep 29, 2017 | Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Gas to stay on
hi. thanks for the question. the part you need to replace is the thermocouple on the gas valve. replace that part. thanks the appliance doc
Oct 05, 2008 | Fagor 5HA-196 X Single Oven
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Ovens Logo
264 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
