Question about Polar S120 Wrist Watch
I have numbers on the screen (and a new battery), but when I press the red button nothing happens
    Guru:
  • 347 Answers
Really the only thing to do is send into a Polar Authorized Service Center. If you did this for your battery replacement then you have a warranty and the service is free. If you used a regular watch place or did it yourself (never recommended) then something could have been damaged inside.
Posted on Mar 26, 2011
How do you "unfreeze" a champion c9 wrist watch?
I am having the same problem. The battery is fine, the seconds are ticking away, but none of the side buttons work. The light doesn't come on and nothing happens with any of the others either. The only thing that did work was pressing all four of the buttons simultaneously, which seemed to totally reset the watch. The problem is it reset but didn't fix the buttons. So now I can't even see the correct time anymore.
Nov 21, 2014 | Geneva Watch Group C9 by Champion Mens...
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
Got "memory failed" measage on
push red button for 15-25 sec
Feb 17, 2011 | Polar S-725 Wrist Watch
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
How do i turn it on?? a friend sent me hers since she got a new one, and it won't turn on...
If the screen is completely blank then you need a new battery, the watches are always "on".
if there are numbers on the screen and you need to know how to get it too start for exercising then just push the red button.
In my tips and tricks page is a tip with a link to download the manual for free.
For battery replacement go to this link.
Jan 25, 2011 | Polar S120 Wrist Watch
Need to sync digital and analog screens?
There are instructions on here and in the tissot website. However in basic layman terms here goes...
Press central button and hold for 5 seconds til 2nd beep heard. press centre of glass to show 24hr CM display. Sync will appear in LCD window.Then press top button (mins hand) until hand at 12 exactly. Then press bottom button( hrs) and again hold til at 12 exactly then press centre button. This hould fix sync.
My problem is that I changed my 4 year old battery today and at first heard a beep, removed battery as fiddley closure of base and redid battery. Now I have nothing at all. Could i have possibly shorted out the watch and what do I do now?
StevieG
Dec 27, 2010 | Tissot T-Touch T33759851
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
Does not start after battery change. buttons are not functioning. display is fixed on 1- 1 SAT. light is off. I tried to reset shorting AC and [-] for more than 3 sec. but nothing happened. I concern it...
mcdevito75 here, Return your watch to whoever replaced the battery for adjustments. ------ If you replaced the battery yourself, you may have mis-aligned the buttons that press against the quartz movement to change the display, you"ll have to go inside the watch and make sure the buttons are touching where they are suppose to. It"s also ossible your new battery is weak from a long shelf life. Here also is Casio contact number, 800-706-2534 Optn. 2
Jul 13, 2010 | Casio WVA105HDA Wave Ceptor watch
My tissot navigator does not react anymore, I touched the screen and know it stays at the chrono part and the digital keeps blinking. Is this a battery problem?
It is a battery problem. All you need is new battery for your watch. After fitting the new battery your watch will be back to normal. Rate me, plz.
Feb 15, 2010 | Tissot T-Touch T33759851
Received my Breo watch in the post today, and i thought it would be simple enough to change the settings...however when i press the A and M button on the back nothing happens, i've pressing it lightly
I´ve had the same problem with two Breos. That´s what I did: I opened the watches put out the battery, put in the same battery and that´s it.
Apr 16, 2009 | Watches
Polar S120 Wrist Watch Logo
149 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
