Question about Kenmore Grilling
I have a stainless steel Kenmore propane grill, model 119.16311800. It has four burners and a side burner on the left. It is two years old and has performed perfectly for two years. I am now having trouble with the flame. It will light and if I only have one burner on it will give a good flame. Lighting additional burners will reduce the flame size, when all four main burners are on they struggle to stay lit. We recently moved, and the grill was out of gas for an extended period. The problem first presented after a relative gave me a gas tank. Initial inspection showed some debris in the valve of the tank itself. I tried removing the debris from the tank with partial success. I connected it to the grill and had the same issue. Got a new tank. Fired up and cooked up some great burgers. thought I was all set until the next time when the new tank also produced the same results. I have not been able to disassemble the burners to check/clean the venturi tubes. (ever) It appears that there is a screw at the rear of the burners that will release it, but they are badly corroded and will not come out by standard means. If you could confirm this is indeed the proper way to remove the bruners I will drill them out and devise a better way to fasten them afterwards. Also, I did read here about opening the gas tank valve very slowly. I disconnected the regulator, waited a few minutes, reconnected and opened very slowly. Light the furtherst burner first and proceeded to find the problem still existed. I understand that the regulator may also be faulty. Given that there is no gauranteed life cycle for any product, can you estimate a typical life span for a regulator? How would I go about checking the regulator? I fear that when I tried to remove the gunk in that old tank some loose particals may have gotten into the regulator and damaged it. Thank you very much for any assistance you can give!
    Brigadier General:
  • 4,736 Answers
With all the you described, your best bet is to replace the grill hose/regulator assembly. It's not expensive and it's not difficult to do. You can find the hose/regulator assembly at any home center or hardware store that sells gas grills. The assembly is universal, but take your old one with you for comparison purposes.
As far as replacing the burners are concerned, that's not difficult either. And you may be able to find the replacement burners at www.sureheat.com , as they made the Kenmore grills for Sears. And yes, the scenario you gave for removing the burners is correct.
Hope this helped you and you will be kind enough to give my response to you, a positive rating.
Happy Grilling!
Posted on Mar 26, 2011
  • Rich Landrum Mar 26, 2011
    Jeff, thanks for the 4-thumbs up approval rating. It's much appreciated.
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Model VCS5008P
Yes thats a problem with the regulator, its not allowing the gas to regulate through to the control which is why its stuck on high. Try http://www.ibuygrillparts.com/50003815.html this is where I get all of my grill parts
May 06, 2013 | Vermont Casting Signature VCS5008P...
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
Kenmore Burner Hissing Noise?
You are on the right track. Check if you can clean the burner. It may help. If you do have to replace the burner, get the stainless steel replacement. It costs a little more, but it lasts 10x longer than the steel burner assembly.
Apr 26, 2009 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Low flame
Either ;
1 your valve is not opening on your tank,
2 your regulator is bad on your tank, or
3 your out of gas.
Unless your second burner is going fine then you have :
4 a bad burner valve control not opening or
5 Some cobwebs inside the burner blocking the gas flow.
If this helps you please rate me with as high a mark as you can. Thanks for using Fix ya and Good Luck
Mar 26, 2009 | Ducane 30400040 Stainless Steel Grill
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
Re: hi
How old is the grill?
When was the last time you cleaned the grill?
Is it Liquid Propane or Nat. Gas?
Apr 19, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
374 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
