Question about Kenmore Dryers
Kenmore series 80--no heat, replaced heating element, thermostat and fuse, what is left? thermal cut off?
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. I can help you but... after reading all of the above it makes me wonder if just one of the 2 CB's for input power are partially tripped or... there may be a terminal problem where the power connects to the dryer on the terminal block.
DO this:
Go to the main CB box and push HARD the dryer CB to OFF then back to ON.
Test dryer
Inspect the terminal block on the back of the dryer for any signs of damage.
I can provide more help but PLEASE provide me with your model number (not Kenmore 80) so I can get you and myself the right manuals and figure out what is causing your problem.
Thanks Kelly
Posted on Mar 26, 2011
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Kenmore elec dryer series 80 not heating up
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Kenmore Dryers
My kenmore series 500 dryer does not heat up
The closest model number reference I could find for what you have provided is "110.69522800". If this model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0809032-00003.png
The components are listed as follows:
Heating Element (Item 14)
Thermal Cut-Out (Item 1)
Hi-Limit Thermostat (Item 34)
Internal-Bias Thermostat (Item 40)
Thermal Fuse (Item 9)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad).
2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. Please post back with your correct MODEL NUMBER if the number I have provided is incorrect. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 19, 2010 | Kenmore 500 6952 Dryer
My 80 series electric kenmore dyer runs but no heat
MY dryer has no heat
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.9df7975.jpg
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Apr 17, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryers Logo
162 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
