Question about Zanussi ZX56 / 4 Bottom Freezer Refrigerator
Compresor working and its body very hot and not cooled
    Guru:
  • 683 Answers
Try cleaning your condensor coils.
Posted on Mar 26, 2011
99 S 80 VOLVO NO AC
First check your temperature control, maybe it is on red marking. Adjust to extreme blue. If it still does not help, then your cooling line is getting too hot and air conditioning systems are designed to trip the compressor if cooling liquid temperature gets higher than optimum running temperature which could be the cause due to your cooling fan not working. To check that switch on the air conditioner and see that your radiator cooling fan is working or not. If not rectify that.
Apr 07, 2012 | Heating & Cooling
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
I have a kenmore elite , Mod# 71203100 mfg=10/10/2001 it worked fine since I got it ..48 hrs ago it was found to be not cooling anymore, lights go on fan's work , but compresor will kick in for 30 sec and...
I would fix it because The way I am understanding the compressor is getting hot and thermally kicking out. This could be a thermostat or a start relay for the compressor. Or it could be low on charge that will also make the compressor shut down because of the head pressure. I would check out my thermostat really close and any start relay's for the compressor. It would be about 200.00 compared to 1200.00 to replace it.
Jun 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Everthing sunddenly thawed out how come? whats the fix can i do it my self
If you heard the compresor running and it's not cooling ,probably is out of refrigerant(freon) ,but ifthere's power in the outlet and the compresor isn't working and is hot to the touch ,could be the relay or the compresor went bad ,also if there's power but the compresor is cold it could be the thermostat is open ( you can check it by putting a jumper in the thermostat wires).
Aug 20, 2009 | Frigidaire Freezers
COMPRESOR GETS REALY HOT IS IT THE SWITCH BAD OR THE COMPRESSOR
Reasons for a hot compressor are:
  1. It is just hot and is not a problem.
  2. Lack of ventilation to compressor.
  3. System is short of refrigerant which prevents the return refrigerant from the cooler being cold enough to cool the comp.
  4. If system is short this could make comp run continuosly trying to reach temperature
  5. If the thermostat is stuck on the inside cooler will probably freeze up, so that shouldn't be it.
  6. Compressor could be "letting by", meaning hot gas goes into the cold side of comp, if that is if it will stop working eventuallly.
Hope that helps.
Aug 03, 2009 | Roper Refrigerators
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
New split system blows only hot air
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Jan 29, 2009 | Heating & Cooling
Zanussi ZX56 / 4 Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Jason Harris
Jason Harris
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
