Question about Toshiba Satellite Pro L300-EZ1501 Notebook
I have a Toshiba l00 laptop with an HDMI out socket. I want to display this on a tv screen. When I connect the cable nothing displays. I have tried the f5 FN key but cannot make the display change from the internal monitor. Can you help?
I had a similar problem with my ASUS, Looking closer at the port, the hdmi connector was not inserted all the way. It felt like it was in all the way but nit was a very tight fit. On my tv's and dvd players the connectors are not as tight. If that is not the problem it may be the tv not seeing it due to The HDCP control, which authenticates the HDMI signal, and is built into the hdmi system. this sometimes requires turning off and on the tv while the laptop is plugged in, or you may have to reboot the laptop with it plugged in. Your tv may require you to go into it's menu and select the hdmi port source. If none of this works, try it on another hdmi tv.
Posted on Mar 26, 2011
  • 26 Answers
I WOULD HAVE TO SAY YOU HAVE TO RIGHT CLICK THE DESKTOP AND CLICK PROPERTIES THEN CLICK SETTINGS CLICK ON THE DROP DOWN MENU DISPLAY AND CHOSE 2 THEN CHECK THE BOX EXTEND ... CLICK APPLY THEN OK HOPE THIS HELPS
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
Try pressing the appropriate function button to change the screen from internal to external. Possibly F4?
How to connect to a sony tv
If your laptop has an HDMI port you can buy an HDMI cable and connect to your Sony TV. Most TVs now come with an HDMI cable
Once connected your TV should show the screen from your laptop if not
press Function and F5 buttons simultaneously! Alternatively you can restart your computer!
Still problem! Go to control panel and click on display and choose Sony TV good luck!
Sep 24, 2011 | Toshiba Satellite Pro L300 Notebook
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I have a toshiba tecra 9100. The laptop will power on, the lights are on and the battery will charge. There is no video, the fan wont come on. When I press the power button I hear a click and nothing more....
you probably have a video card problem or a screen problem, im guessing the OS does lunch but you cannot see it. try connecting it to another display (i.e tv or another monitor and press the TV out buttons) preferably try connecting it through an HDMI port if it has one that is because an HDMI would start the display on the new monitor without any set up most often.
May 18, 2011 | Toshiba Computers & Internet
How do I get my Toshiba Laptop to project on the Sharp TV I connected the VGA cord?
Tries connect it with HDMI cable to tv HDMI hub to the Laptop USB hub this the best result,not many problems with capatabilities this way.
Jul 06, 2010 | LG 32LG30 32 in. LCD HDTV
Connect laptop(with HDMI output) to TV( with s-video input)? Hi I have a laptop in which there is port for HDMI output and TV with S-Video input. I bought a cable (HDMI HDTV to VGA HD15 Y/Pb/Pr 3 RCA...
Here how you can connect a computer running windows vista to projector or other external display.
  1. Open Personalization window by right clicking on empty desktop and choose "Personalize",
  2. In the Tasks list click on "Connect to a projector or other external display" link,
  3. The Windows Mobility Center appears, in the presentation settings box click the turn on button to turn on projector,
  4. Now your screen will show up on projector screen around large display as well as your own computer screen,
  5. If you want to change the presentation options click the Projector icon inside presentation setting box,
  6. The Presentation Settings Windows appears, if you turned on the projector the "I am currently giving a presentation" checkbox is selected,
  7. When you are giving a presentation your computer stays awake, system notification are turned off and by default the screensaver is turned off,
  8. You can also set the system volume to show different windows wallpaper in the one you usually use, when the presentation ends and you turn off the projector your regular desktop wallpapers returns,
  9. If you are not sure what displays are connected click "Connected displays..." button on bottom of existing window.
Jan 10, 2010 | Office Equipment & Supplies
Connecting a laptop to a tv
You have to tell the laptop to use an external display this usually involves pressing the FN + F5 on and acer but does vary from laptop to laptop
the second key usually has two screens printed on it
Dec 31, 2009 | Computers & Internet
Connect Laptop to TV via USB
Hi i have only connected my laptop to the tv a few times. i did it through a scart lead connecting to the s-video-out socket on my laptop. then i when to display propertise , settings then selected screen 2, then extened to desktop monitor. it worked. i then opened a film in my player, dragged it accross, went full screen job done. hope this helps...
Nov 22, 2008 | Acer Aspire 5100 Notebook
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Open Questions:
Toshiba Satellite Pro L300-EZ1501 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
