How to change from antenna to cable mode - Televison & Video
  • 68 Answers
Some models its doo automatic vhen memorized stations in auto mode
Posted on Mar 26, 2011
How do i hook up a 32 inch Sansui TV to an antenna
After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
Oct 22, 2015 | Sansui Televison & Video
How do I change from cable to antenna?
Without knowing the make and model it is difficult to answer your question accurately. In general you would change either the source or input option. Usually the antenna option is called TV.
Sep 08, 2015 | Televison & Video
How do I change from cable to antenna input
Its in the menu for the set--on screen and is done with the remote---you want to move to antenna/air.
Even if in cable mode it should pick up any active channels 2-13.
Dec 03, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
I have a ilo tv model 26hd it's stuck in cable mode
Go into the menu with the original remote and in the setup should be a selection for cable or air/antenna------you likely need the original remote to do this.
Oct 29, 2012 | iLO Televison & Video
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Need to disconnect cabl;e and used rabbit ears for outside use,,TV will change off blue screen from cable
you need to get to the menu and change your tuner mode from cable to t.v antenna air signal
Sep 21, 2009 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Emerson ewv404 catv to antenna
There is an option in the menu which changes the tuner from cable to antenna (off-air or broadcast) mode. On many/most late VCRs, you must have the remote box to access these functions.
Old VCRs (15 years +) might have had a switch to make this change.
Nov 01, 2008 | Emerson EWV403 VHS VCR
27 inch symphonic
with the set turned off press the game
button and if it comes on it should be
in game/cable mode
Oct 31, 2007 | Symphonic ST419E TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
