The power light on my lacie external hard drive is usually green now the light is orange and it is not regonized in my computer.
  • adam5 Mar 26, 2011
    Tried other computers sane thing, i forgot to mention hdd makes like a beep sound.
    Guru:
  • 1,705 Answers
It looks like your HDD has a problem, try it on another PC, if you get the same result, its probably failed. If it works ok, your PC has a problem, may be as simple as the usb slot has dust in it.
Posted on Mar 26, 2011
  • dgsturt Mar 26, 2011
    What I said stands, if it doesn't work on another pc its probably failed, but, you've not said which model it is, so I can't research the issue on the Lacie web site, but you can :-
    Here's the url:-http://www.lacie.com/uk/products/range.h...
    They've got a support page and a download page. You should be able to check their FAQ's and download a user manual for your model.
  • adam5 Mar 27, 2011
    Thanks. I'll try that.
We understand that your problem is: We understand that your problem is: Hello, I have Lacie porsche external hard drive. I also have a seagate firewire external drive which us working fine. Unfortunately...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Disc not recognised by computer, orange light showing on front
Orange light and clicking noise sounds like the hard drive has failed.
The enclosure should still be good so if you can open it and replace the hard driver you will be back in business.
Good luck.
May 29, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
My lacie hard drive is not spinning up. the light
if still in warrenty return to reseller for replacement but if outta warrenty open it up and try the hard drive in a pc and see if it works ok if it does u just need a replacement external caddy which can be found quite cheaply on most auction websites ;)
Mar 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
Drive won't mount and makes slow clicking sound
A power supply failure can cause this; I've just been through it myself. If you have access to another LaCie drive, try its power supply on the "failed" one and see if it works.
Mar 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
