Question about Sony STR-DE695 Receiver
A fuse (F901) T2,5 A. bruns when I plug in de power.
I have a Hannspree LCD TV Model HSG1113, the big yellow transformer on the power board has burnt (2cm area) the PCB underneath it. There's a type of fuse (f901) T4AL 250 V that's blown. How can...
eu tenho um lcd ke o comando a distancia nao funciona e o led pisca a laranja mas o mesmo comando noutro lcd funciona o ke tenho ke faser
Jun 11, 2011 | Televison & Video
I have the same problem. The fuse blows every time I plug the Sony STR-DE135 into the wall. I did not find the F901 at Radio Shack, so I bought a fast acting 5 Amp 125V Fuse at the Hardware store. It blew...
There is usually one or two normal clicks on power-up. A self-protection relay activates after a short delay for circuit and power stabilization plus some internal cheking for shorts and thermal issues.
If it keeps blowing fuses you are stressing it a bit more every time you feed it another one. I'd get it in to a Pro for repair.
Mar 02, 2010 | Sony STR-DE135 Receiver
Need f901 fuse
Here: http://www.mouser.com/ProductDetail/Vishay-Beyschlag/MFU0805FF04000P500/?qs=sGAEpiMZZMseCiJT91fwIrhcnEoxWl66pg5mWW1VsJQ%3d
Sep 12, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Cant update your console. please contact xbox customer support or go to www.xbox.com thats what it says when you turn it on?
Download this file, extract the default.xex
Default.xex.rar
Download this file, extract the Folder $SystemUpdate
$SystemUpdate.rar
Brun the default.xex and the folder $SystemUpdate an an CD-R
Plug it in your Xbox.
finished!
KonsolenSupport.de
Aug 31, 2009 | Microsoft Xbox 360 Console
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
No Power
all sets must have rated fuse for protection. some units now use what is called a PICO-FUSE.this type of fuse is soldered into the pc board. usually marked with location i.d. F301,F901,F400. etc. these fuses look like resistors or in-line coils. check continuity w/ohm meter. if new fuse blows as soon as you plug in tv, suspect bridge diode ciruit or main filter cap(large ripple filter by main fuse. if new fuse blows when you try to turn on, suspect 130v regulator or high voltage short(horizontal-output, flyback transformer) good luck!
Feb 20, 2009 | Televison & Video
Iris problem with PT-AX100U projector
le probleme est du par les pivots de l`iris qui manque de lubrifiant. il a deux pivots a lubrifier, le premier se lubrifie sous le projecteur dans le compartiment de la lampe.
il est de couleur brun et il a un petit resort autoure de lui, il est en plastique. prendre un micro
tournevis et le faire fonctionne. il doit revenir sur lui meme rapidement,lentement pas bon il faut
le lubrifie. seulement une petite goutte suffit.
le deuxieme est plus complique,il faut ouvrir le projecteur. les vis sont sous le projecteur indique
par des fleches. il en a une autre sur le dos .attention il est difficile de separer les couvercles
on peut voire le pivot sous une petite grille de metal il est brun lui aussi
ps prendre le tounevis pour applique le lubrifiant atf dextronIII
Oct 23, 2008 | Televison & Video
Norcent LT2722
The fuse is good if you're still seeing some kind of light on the front of the LCD. There might be defective capacitors in the power supply and that is why the LCD is not powering up, but also there is a possibility that the back light inverter board might be defective.
Let me know if you need further assistance.
Oct 15, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Sony STR-DE695 Receiver Logo
88 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
